Results 1 to 6 of 6
Thread: How long does it take?
    Jun 2005
    I was wondering if anybody knew of a formula to determine how long it takes for a winding of a step motor to reach full current. I can see it as a function of resistance, inductance, and voltage, but am not certain how they are all mathematically related. Thanks
    Feb 2007
    that all depends on the speed and load the motor in under,if you where moving fast and hit somehting solid,the motor would reach full current quite instantly,why do you want this info?if i may ask?usually one doesnt worry about the time to reach full load,only that the motor is suitable for ones use
    Jun 2005
    I am writing a report on some of the phyiscs of step motors. Included needs to be plenty of formulas .
    Jul 2005
    The correct answer is infinity but you can assume 3 RL time constants
    http://www.physics.isu.edu/~hackmart...itsgenphys.pdf
    Aaron
    Jun 2005
    Thankyou . For some reason, I never thought about steppers an RL circuit. I just had a "duh" moment
    Jul 2005
    Quote Originally Posted by phantomcow2 View Post
    You can make the assumption only at very low speeds - BEMF and geometry variations will cause all kinds of fun stuff to happen as things rotate
    Aaron
    1. How long did it take to build your first
      By justCNCit in forum CNC Wood Router Project Log
      Last Post: 03-05-2007, 12:58 PM
    2. How much is too long?
      By monte55 in forum Xylotex
      Last Post: 11-30-2006, 09:48 AM
    3. How long does it take
      By CNCadmin in forum Steam Engines
      Last Post: 11-08-2006, 10:45 PM
    4. Long end mills
      By PTcutter in forum General Metalwork Discussion
      Last Post: 06-16-2005, 07:29 PM
    5. Not long now
      By CRFultz in forum DIY CNC Router Table Machines
      Last Post: 01-11-2005, 02:13 PM
