Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 03-02-2007, 09:09 AM
jeffg is on a distinguished road
Need Help With Stepper Drive
Hi so many to choose from. I have some vexta steppers they are the same size as PV269 4 wire bipolor 440 oz/in but mine have a custom winding 4.4a 2.5v I have been looking at lots of drives but i am not sure what amp. rating i need? If i use a microstepping drive do the motors need the full 4.4a I have a 38v 10a unregulated power supply. Many of the cheaper drives are only 3a. Any info you can give my will be helpfull i am a nubie! Here are pics. of my steppers thanks.
ID:	32767   Click image for larger version
Old 03-02-2007, 10:17 AM
jeffs555's Avatar
jeffs555 is on a distinguished road
You can run the motors at less than their rated current, but torque is directly proportional to current, so at 3 amps the static torque would be only 68% of what it would be with 4.4 amps. However, static torque is not usually the problem. Torque on any stepper drops off as speed increases. At some speed the torque will be so low that the motor starts losing steps. At a 3 amp setting, the torque will not drop as quickly with speed as it would with 4.4 amps. At some speed the torque will be the same whether the drive is set for 4.4 amps or 3 amps.
Old 03-02-2007, 10:29 AM
Konstantin's Avatar
Konstantin is on a distinguished road
You wont have to worry about the amperage if you choose to go with a chopped drive, just configure the chopper for 4.4A. Microstepping does not force you to use rated current (imho) it just smooths the motor rotation at low speeds. Your PSU will be barely enough for 2 motors like that.
Are you sure the motor holding torque is 440 oz/in? Imho it looks too small or your hand is really huge , I would guess its about 200ish.
Do you want to make your own drives following a free design or to purchase already made ones?
I dont recall that we have bipolar drives for +3A here on the zone, at least Pminmo has none of that rating, you look at his web at www.pminmo.com.
What is your idea for that motor? Do you have a design for your mill/router/lathe ?
Konstantin.
Old 03-02-2007, 12:31 PM
Thanks for the info.I guess my hand is pretty big? I got the steppers on ebay they are 60mm x85mm the only size that match at vexta is pv269 they are 440 oz/in I called vexta the tech. said it was a custom winding and if i could supply full amps my motors would have more torque than a stock pv269.On the psu it was a 24v 18a regulated i removed the regulating board and now i get 38.9v at the capacitor i am not sure what the amps are at 38v?I might have to upgrade to a bigger psu? I am building a 4x8 router table [my 2nd] The 1st table has poor preformance.I want to get the best preformance for the least$$$on the new one.I was thinking about keling drives? I am posting pics. of table,psu and pv269 specs. tell me what you think ?
ID:	32774   Click image for larger version
ID:	32775   Click image for larger version
ID:	32776   Click image for larger version
Old 03-02-2007, 02:49 PM
Konstantin's Avatar
Looks interesting.
Have you measured the impedance of the stepper coils?
Konstantin.
Old 03-02-2007, 03:10 PM
No sorry i am not good with electronics this is all new to me thats why i need help. i dont want to make a costly mistake.
[IMG] code is Off
Which drive for which stepper? paul3112 Gecko Drives 0 07-30-2006 08:50 PM
Where to buy Stepper Drive Box camsoft Stepper Motors and Drives 2 05-23-2006 07:59 PM
difference between a stepper indexer and a stepper drive pcroxford Stepper Motors and Drives 0 11-02-2005 07:35 AM
Two stepper on one drive TigerPilot Open Source Controller Boards 4 03-22-2005 01:32 PM
stepper drive help bbrreid General Electronics Discussion 3 08-28-2004 01:45 PM
