Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 02-23-2007, 09:18 AM
oldik is on a distinguished road
Microstepping with L6506, L6503 and LPC2138
Hello all,
Im, newbie here. I have a problem with my diploma work, I have to drive stepper motors with microstepping, I use two H bridge L6203 and one bridge L6506. I have development kit with arm7 - LPC2138, but there is 3,3V logic and L6506 need higher supply voltage, I dont know if it woud be ok, if I use 3,3V in procesor and 5V in driver L6506.
Thanks of all idea.
Oldriska
Old 02-24-2007, 04:05 AM
jeffs555's Avatar
jeffs555 is on a distinguished road
Usually, you can drive inputs on 5 volt parts from outputs on 3.3v parts, but you need to look at the data sheets for both parts to be sure. You generally can't drive inputs on 3.3v parts from outputs on 5v parts, without using a voltage divider.
Old 02-24-2007, 10:02 AM
kreutz is on a distinguished road
Go to the Texas Instruments website ( www.ti.com ) search under "Dual supply Level Translators" or " Dual supply translator" and you will find what you need.
[IMG] code is Off
MICROSTEPPING with L6506 and L298 LOKI Open Source Controller Boards 4 11-04-2010 07:10 PM
L6203+L6506+DAC+MCU=Where? Cooper Open Source Controller Boards 0 01-24-2007 01:02 PM
L6506/IRL540 Unipolar Chopper Drive JonLed Stepper Motors and Drives 25 07-11-2006 10:25 AM
New pic for microstepping ajv2803959 Open Source Controller Boards 5 03-21-2005 11:59 PM
Microstepping question TimW DIY-CNC Router Table Machines 2 03-29-2004 09:21 AM
