Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 02-23-2007, 07:34 AM
jeffg is on a distinguished road
Need Help Matching Steppers To Screws
Hi everyone and thanks for all the help. I have 3 vexta steppers they are the same size as pv269 4 wire but they have a custom winding the pv269 has 2.8a 4.2v my steppers are 4.4a 2.5v i called vexta the tech told me that my steppers would have more torque if i could supply enough power. My 1st question is more torque and less speed or more torque and more speed than stock pv269 ? how do you think my steppers will preform using a 38v power supply? I am building a 4x8 router so i dont know if i should use a 10 tpi lead screw or a 5tpi lead what wouid be a good balance for speed and torque? here are the specs. for the stock pv269. Feel free to give me some ideas thanks
Old 02-23-2007, 07:57 AM
ger21's Avatar
If they are 440oz motors, I'd use a 5tpi max, maybe even 2tpi. And up to a 50V power supply. More voltage will give you faster speeds.
[IMG] code is Off
In progress - 8020, linear rails, ball screws, steppers stevespo CNC Wood Router Project Log 123 03-02-2012 05:43 PM
Inductance matching drives? pdunster TEKdrive Servodrives 4 09-07-2006 06:01 AM
How Important is it to have matching ball screws? journeyonline Linear and Rotary Motion 3 01-19-2006 09:39 PM
Matching the electronics Parameter General Electronics Discussion 6 07-15-2005 11:45 AM
motor mixing and matching... charleyy DIY-CNC Router Table Machines 8 09-05-2004 11:32 PM
