Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 02-23-2007, 07:06 AM
dbunic is on a distinguished road
17PM-H311-P1 specification
Hi!
I have searched a lot and cann't find specification for that MINEBEA stepper motor.
I know that it's a unipolar stepper (6 wires) and as I measured resistance it's about
7 Ohm PH. So any help is appreciated.
Thanks in advance.
PS. Here is all what can be read from motor
ASTROSYN STEPPER
AST P/N 17PM-H311-P1
LOT NO. T2Y25
MINEBEA CO.,LTD.
MADE IN THAILAND 761-03
Old 02-25-2007, 06:25 AM
lucas is on a distinguished road
this site has(d) the info:
http://www.eminebea.com/content/html...or/index.shtml
but I can't open it now, maybe their server is down?
If you can't access it in the near future: I have several similar motors and might have printed or noted down info, just let me know.
Old 02-26-2007, 01:59 AM
Originally Posted by lucas View Post
Thanks for your answer.
I've searched their site and can't find docs for PM-H series
As I can see H series is also "hybrid" not "permanent" type and the base of the motor
is quadratic not circle.
I have attached image of motors label ...
In the mean time, I buy digital multimeter and measured resistance of coils. So from
the one end to the middle tap, resistance is 7 ohms. Motor has 6 wires.
After reading similar specifications for the minebea motors, I can suppose that current can
be about 0.6 - 0.8 amps but it would be much nicer to have original data.
Thanks in advance.
Old 02-26-2007, 02:11 AM
Thanks for answering ...
Thanks in advance.
Old 03-01-2007, 10:22 AM
You probably have a custom motor, finding the exact data will be difficult if not impossible.
This page describes the model number digit information:
http://www.eminebea.com/content/html...st/index.shtml
You will have to compare with a similar motor and eventually start driving it with lower amps and increase if needed.
Old 03-08-2007, 03:43 AM
Thanks ...
Old 03-08-2007, 01:11 PM
toneV8 is on a distinguished road
lucas: do you know how much torque have this stepper.
MINEBEA CO.,LTD
34PM-C042
3A/phase
1,8deg/step
class B
Old 10-22-2007, 11:04 PM
workfine's Avatar
workfine is on a distinguished road
astrosyn hybrid
hi
info for just helping you thank's
Old 03-25-2008, 11:36 AM
PatriceRene is on a distinguished road
Did you get the specification of this stepper motor
I've 2 motors of that type
Regards
Old 04-15-2008, 04:06 PM
Ernst is on a distinguished road
Home build CNC with steppers type 34PM-C042
I have a home build CNC machine with on xyz axis steppermotor type
34PM-c042.
It seems the max stepping rate is about 1500 steps/sec. I don´t know if this is rather low or high? In the software I set 400 steps for 1rev, to move 2.5mm. The max speed to calculate is 9.375mm/sec.
The motor gets 2Amp. (This is not measured but a controller spec.)
Looking for specifications to. Wondering how to increase speed.
  #11   Ban this user!
Old 11-26-2010, 12:46 AM
littlemaster is on a distinguished road
hi
i searched alot but i didn't find datasheet of 17PM-M008-10V stepper motor
can any one help me
how i can get detail about the features of this stepper motor
following data is written on the stepper motor i bought
i need to know about the current rating, step angle and voltage rating of this motor
data written on the stepper motor
Astrosyn Stepper
17PM-M008-10V T2817
IBM P/N 38H7340
IBM EC/N E44302
insulation class B
MINEBEA CO.LTD
Made in Thailand
[IMG] code is Off
Techical specification Electrocraft 0643-08-013 ? wotje Servo Motors and Drives 6 09-11-2011 09:29 AM
Steel Tubing specification question ad_bfl Mechanical Calculations/Engineering Design 1 10-24-2006 04:31 PM
R8 Spindle Specification (M1TR?) lmartin1001 Mechanical Calculations/Engineering Design 1 10-16-2006 01:13 PM
Open Source CNC Controller Specification gregmary DIY-CNC Router Table Machines 28 12-04-2005 09:58 PM
What's the Specification to buy Step motor fro G210 ? Calico Gecko Drives 6 04-14-2005 12:26 PM
