| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
I know the better reduction units to use are planetary gearboxes. But these are from what I gather, straight cut gears. Are they worth considering for use on a CNC gantry plasma system. They state arc minutes down pretty low. 2.5, 4 etc This seems pretty tight. http://anaheimautomation.com/manuals...ec%20Sheet.pdf Any comments? Peter Australia |
| the average back lash is 4 degree even if you can adjust the backlash in the controller there will still be a dwell at the axis reversal this would distort the geometry you are trying to create to some degree if you need that much torque use servo motors |
| To get 4 arc-min or less you need a VERY expensive planetary from what I can tell from trying to solve the same problem. As just mentioned above, these units are 4 >degrees< which is insanely sloppy. Since so far I only have used reduction to get more resolution (increase in my steps per rotation), harmonic drive worked for me to get that, but obviously that doesn't work for gearing down to get greater torque. I don't know what you to do for that, especially for something that large, save getting a bigger drive (or multiple drives on that axis), or servos.... I am now running into the same problem you have right now, so if there are any bright solutions other than stupid money for planetary gearheads, Let me know! |
| Depends on the gear ratio you are looking for. I have seen a gentleman selling some nice 3:1 boxes on Ebay from SPD SI every so often.
__________________ (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) "If the women don't find you handsome, they should at least find you handy" -RedGreen show. |
| Those gearbox's would work great for some non-critical function, but for NC machine control they will not be very usefull. You'd be better off using a belt reduction over those units. If you guys are looking for cheap reducers I'd be looking on ebay. I've bought all new reducers for my machine [they were like $700 each] and then later bought three off ebay for $75. These are Nema34 10:1 reducers. I saw a 10:1 on there the other day that didn't even sell for like $20 or something. I'd have bought it, but I've got 9 of these things hanging around now and don't think I'll be needing more for a while. Anyway, they do exist and can be bought cheaply off ebay. I waited for 1/2yr and never found them, so I bought new. A week after they arrived I got these cheap ones. [Just my luck ]. Also harmonic drives would be an option depending on what kind of reduction your looking for.Jerry [giving my best, secret "bargain stops" away for free ]
__________________ JerryFlyGuy The more I know... the more I realize I don't (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Direct or geared reduction to threaded drive ? (stepper) | andy_ck87028 | Linear and Rotary Motion | 4 | 03-13-2006 07:42 PM |
| Planetary Reducers | JerryFlyGuy | Mechanical Calculations/Engineering Design | 6 | 01-28-2006 01:03 AM |
| For what its worth...FYI | jer29_11_13 | General Metal Working Machines | 0 | 07-22-2005 09:03 AM |
| Geared Stepper and Current Controll | krazycnc | Xylotex | 3 | 05-31-2005 10:34 PM |
| Converting a mini from geared to belt driven | CNCadmin | Benchtop Machines | 1 | 11-04-2004 10:15 AM |
