Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 02-14-2007, 09:36 AM
Scra99tch is on a distinguished road
Picking out a power supply
I am a bit new to this so bear with me. I am trying to pick out the best power supply for my setup which is comming along quite nicely.
Trouble is I do not know what the best power supply I can use for full effect.
MY setup will be as follows.
3 Slo Syn KML062F07 Stepper Bipolar (4 wires) rated at 2.48 Vdc and 3.3 Amps (nameplate stats).
3 IMS IM483 Drivers which run at 12+ to 45+vdc with 3A peak* (depending on input current).
I also need to supply the opto supply 5vdc+ for the inputs, my table has two hall effect switchs which I believe run at 5-9vdc.
And last but not least possibly a 24-48V Servo motor hopefully able to cut machine steels.
Any tips suggestions would be appreciated thanks.
By the way I am using a 24vdc switching powersupply 2A type Matsu****a and its powering my 1 axis test stepper just fine no stalling or heavy resonance.
And I would like to avoid that intial jump when poiwering these steppers up
Jim
Old 06-20-2007, 10:59 AM
NEATman is on a distinguished road
My favorite trick for a 5VDC power supply is the PC itself. Purchase a USB extension cable, cut off the end that dosen't connect to the USB port and pull the 5VDC from that. Just use a voltmeter between the case of the PC and the 4 seperate leads, and you will find the one that is 5VDC. This also helps minimize the chances of voltage spikes harming your computer, as the power is coming from the PC to begin with.
NEATman.
Old 06-24-2007, 05:27 PM
cnczoner is on a distinguished road
Be careful with this though (5V from the USB port) -- make sure you don't need more than 100mA total. The port is spec'd to deliver 100mA and if the USB application needs more, it will request it using the USB protocol. The PC, if it can honor the request, will then allow 500mA IIRC.
[IMG] code is Off
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
Help with Power Supply starcat Automation Technology Products 20 10-30-2007 09:34 AM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
Power Supply Help SteinAir General Electronics Discussion 3 01-05-2005 11:58 AM
Power supply kenlambert General Metal Working Machines 6 03-24-2004 04:15 PM
