| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
| The steper motors I have max out at ~50 RPM before they skip (no load) They are 6.3v 2Amp 200 oz/in 1.8 deg. I am building a small gantry router 24"x24" and this is not really fast enough..... only 10 IPM with a 5 TPI direct drive screw. I thought I could get a much higher RPM from these stepers. Are there any engineering guidline charts for this sort of thing? Can there be a problem with the L297/298 driver output signal? Can a cleaner power supply help this much? Is this just the limit of a 6.3V steper motor |
What voltage and current is your power supply? |
#10
| For the normal operation L298 IC the motor current is controled with PWM (Pulse Width Modulation) and the motor supply voltage has to be more than the rated motor voltage I would of used a minimum motor supply of 20V a voltage close to the maximum 46V gives a higher motor speed John |
#11
I am not doubting you on this formula, but could you tell me where you find it? I've had discussions on other web sites about this but can't find a definitive proof of my belief in it. Thanks for your help. |
| Bridgeport steper motors | hello113 | Bridgeport and Hardinge Mills | 1 | 07-11-2006 12:07 AM |
| steper type to use | eloid | CNC Wire Foam Cutter Machines | 1 | 04-18-2006 01:03 AM |
| Steper Motor TO HOT!!!! PLEASE HELP | Chivo | Stepper Motors and Drives | 6 | 11-10-2005 10:08 PM |
| Steper Motor & Driver Problem -Please Help | Chivo | Gecko Drives | 5 | 08-29-2005 06:10 PM |
| Steper Motor & Driver Seting--- Please Help | Chivo | Stepper Motors and Drives | 4 | 08-24-2005 07:15 PM |
