Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 02-12-2007, 07:36 PM
shadesdude is on a distinguished road
Defective stepper or driver
Alright, this has had me pulling my hair out.
I am using a stepper driver from stepmaster - datasheet
I am pretty sure it is working correctly. I have adjusted the current and PFD according to that sheet. Voltage tests show ~5v comming out of A and B# all the time and ~5 v out of A# and B when I enable the axis.
My stepper motor is Lin Engineering's 4218L-04-07 1.2A 6 wire stepper wiring guide (red, white, blue, green, yellow, black)
I don't actually have a data sheet but I have confirmed that the wires that are shown in the wiring chart are infact correct through resistance testing. So when I connect the servo according to the half coil method I should have
-----Setup 1---Setup 2
A----Red-------Blue
A#---White-----White
B----Green------Black
B#---Yellow-----Yellow
Neither of these setups produces anything but a small shuddering that occurs even when the axis is disabled. So I tried to wire it in series (A-red, A#-blue, B-green, B#-black) this time with no results. I then tested the servo by rotating the contacts between a 9v and I was able to get it to rotate fully (with a wire in between each fingers this was really fun). So maybe I'm missing something obvious or I just misread something but I'm out of ideas so any help would be greatly appreaciated.
Old 02-13-2007, 10:02 PM
pminmo's Avatar
pminmo is on a distinguished road
I would suggest you contact stepmaster. Doubt the motor is the problem.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 02-14-2007, 11:41 PM
kreutz is on a distinguished road
A----Red-------Blue
Something is wrong, even when using the 6 wires motor in bipolar full coil you should have 1 wire for each phase unconnected, in the case of full coil it is the center wire for each phase the one that is not connected (equivalent to bipolar series), in the case of half coil is one of the extremes for each phase, the ones that should be left unconnected.
[IMG] code is Off
STEPPER DRIVER FAQ {Stepper/driver amp per phase match. huios Stepper Motors and Drives 0 08-27-2006 08:43 AM
Defective toroidal? JMValios General Electronics Discussion 3 12-15-2005 04:45 PM
Donate your defective G201. creative_mind Gecko Drives 12 02-12-2005 02:08 PM
