| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
hello i recently build alan picstep driver i set it up to 1.6amps and powerd it with 30volts i used a 1.6amp 2.7volt bipolar stepper. i didnt use a computer i just used a small pic 16F628A circuit that generated a pwm frequency to feed the step signal i tied the enable to ground . now the problem the max frequency i can feed to the driver before the motor stall is 18khz. then it stalls ( i tried it up to 20khz) (50% duty cycle) i tried changing the input voltage (lower it to 12V) but there were no effect on the motor speed at all, just a lower noise from the motor. the motor speed is not high at all, i estimate it to be about 200rpm or something like that. am i missing something here ? i know that the frequency can go much higher than that but the motors stops and make a hissing noise. i dont know if this is important or not but i replaced the 1uf capacitors on alan circuit with electro caps. ( i dont have any mkt on hand), also replaced the 2.2nf with 2.6nf i will appicate any help here thank you |
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
| hi again phil well i just removed both jumpers on picstep board to switch to least microstepping and the speed was even lower !! now the max frequancy i can feed is about 2khz !!! i tried 1/4 1/2 steps but still the same problem what am i doing wrong !!! |
| What kind of speed are you expecting? 18khz at full step would be 90 rps, and you're not going to get anything near that with a conventional driver. A lot of factors go into speed. 2K at full step is 10 rps which is pretty respectable.
| STEPPER DRIVER FAQ {Stepper/driver amp per phase match. | huios | Stepper Motors and Drives | 0 | 08-27-2006 08:43 AM |
| Stepper-High Pitch/Frequency Noise | azt34 | Stepper Motors and Drives | 0 | 05-18-2006 07:41 PM |
| Stepper Driver | girandola | Stepper Motors and Drives | 0 | 02-17-2006 10:12 AM |
| Has anybody used this stepper driver? | phantomcow2 | Stepper Motors and Drives | 4 | 10-26-2005 09:25 PM |
| New Stepper Driver?? | ViperTX | Stepper Motors and Drives | 3 | 08-04-2005 06:46 PM |
