Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 02-07-2007, 08:34 PM
veteq is on a distinguished road
stepper setup, Electrical noise ?
Hello guys,
Do you know off the setup off a nema 34brush servo next to
a nema 23 stepper,
(about 3 inch distance)
will create some sort off electrical noise, would/could it be possible to shield this setup in some sort off way?
Some advice will be nice !
regards,
Roy.
Old 02-07-2007, 09:45 PM
Gold Member
Mariss Freimanis is on a distinguished road
No effect on each other.
Mariss
Old 02-07-2007, 09:49 PM
Konstantin's Avatar
Konstantin is on a distinguished road
Imho, if you shield the encoder cabling of the servo and if the stepper motor cables are in twisted pairs each phase, there should not be an issue, maybe keep the stepper and servo cables separate as well.
Konstantin.
Old 02-07-2007, 10:31 PM
Mariss
nice to hear, it`s good for my design.
Another question in relation to the one above then;
If i use the mcg ID33003 with a gecko g320 at 75VDC and, max 15A peak for spindle control for the endmill, the servo will turn max.3000 rpm (geared up to 10000rpm)
could the servo turn 3000 rpm for lets say runs off 1hour, or will the brushes die premature. ( for a hobbymill milling alu small diameter)
Kind regards,
Roy b.
[IMG] code is Off
RF noise causing stepper chatter PsyKotyk General Electronics Discussion 3 08-08-2006 08:42 PM
Preferred Stepper Driver Electrical Interface JeremyLee Polls 4 02-26-2006 03:08 PM
Electrical Motor Noise Sherline Mill JohnAn Machine Problems, Solutions , Wireless DNC, serial port 2 01-03-2006 08:33 AM
Electrical noise. MrBean General Electronics Discussion 3 01-13-2005 06:25 PM
spindle electrical noise balsaman General Electronics Discussion 9 10-21-2003 08:41 PM
