Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 02-03-2007, 06:37 AM
NASR1 is on a distinguished road
how can I control a stepper with an encoder?
Hi all
I need to be able to contol a motor simply by turning an encoder shaft and have the motor respond in position, velocity, and direction accordingly.I need a schmatic of stepper controller with an encoder.
I find about this subject in internet. http://www.webx.dk/oz2cpu/20m.htm
how to connected this circuit with stepper controller.?
thank you any advice would be nice.
nasr1.
Old 02-03-2007, 08:22 AM
nophead00 is on a distinguished road
I think that is a circuit to use a stepper as a shaft encoder. It looks like it produces two outputs which will be square waves 90 degrees out of phase with each other as the stepper is rotated.
Old 02-03-2007, 08:27 AM
To drive a bipolar stepper you would simply need to amplify the two signals to provide sufficient voltage and current for the coils. To drive a unipolar stepper you would need a couple of inverters to make the four signals before using a drive chip to amplify them.
Old 02-03-2007, 09:03 AM
Thank you for response.
Do you have a schmatic of stepper controller with an encoder.?
Old 02-03-2007, 09:58 AM
Sorry I don't have a schematic. You don't need a stepper controller with this scheme, just a driver chip. The type of driver chip would depend on the specification of your motor. As a simple example to drive a small uniploar 12v motor up to 0.5A per winding you could use something like a ULN2803. It has 8 darlington drivers and you can connect them in parallel in pairs to make four higher current channels. You could take the A and B outputs of your example circuit and invert them with somthing like a 74HC04 to make A-INV and B-INV. Feed those four signals into the 2803 and connect the outputs to a unipolar motor. These have two center tapped coils. Connect the taps to 12V. Make sure connect the outputs correspoing to A and A-INV to one coil and B and B_INV to the other.
Connect a small stepper with the same number of steps J1. When you turn it the output stepper will follow provided you don't go very slowly or too fast.
[IMG] code is Off
Big PacSci Stepper with Encoder sdantonio Stepper Motors and Drives 6 06-21-2006 10:26 AM
Can DRO encoder be used for motor control? bicycleboy Gecko Drives 1 05-03-2006 04:59 PM
encoder-stepper motor granado Stepper Motors and Drives 2 11-29-2004 04:38 AM
Stepper with 200 cpr encoder mdoan Stepper Motors and Drives 7 10-21-2004 08:59 PM
Stepper motor with encoder? buscht Stepper Motors and Drives 3 07-12-2004 09:53 PM
