Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-30-2007, 12:49 AM
Bryanpl is on a distinguished road
PowerMax II Stepper Help
All:
Would really appreciate some help on my little project. I have acquired a dual shaft stepper motor connected at both ends to pump heads. This item is surplus and is designed to dispense minute ammount of liquids. The flow rate according to the mfg is 50ul per revolution (200 steps).
http://cgi.ebay.com/Fluid-Metering-I...QQcmdZViewItem
I need to find/build a controller that can control the stepper motor by rotating it in the neighbourhood of 1.5 to 20 rpm to dispense the required amount of liquid.
The stepper motor is a PowerMax II Model #P21NSXS-LSS-NS-04. It is a special OEM model, but from another CNCZone thread it appears the specs of the motor is as follows.
http://www.cnczone.com/forums/archiv...hp/t-7887.html
POWERMAX II 1.8 STEP MOTOR
MODEL: P21NSXS-LSS-NS-04
CUST. P/N: 30028
Is(dc): 1.16A BIPOLAR SERIES Vs(dc): 65V
Po: 30 W T:90C MAX
W: 1500 RMP AMBIENT: 40C DATE: 975014713
What can I use to power/rotate this stepper?
Would half-step be the best mode due to the low rpm?
What about the power supply 12-24V?
Will one of these qkits work for this particular motor?
http://store.qkits.com/moreinfo.cfm/QK158
Appreciate any help.
-=Bryan=-
Old 01-30-2007, 09:41 AM
Gold Member
CJL5585 is on a distinguished road
Homemade Controller
Brian,
All you need to complete your application is a variable frequency 5 volt square wave generator, a 5 volt logic supply, and a stepping motor controller with power supply.
The variable frequency generator will need to be adjustable over the range of 100 Hz to 5000 Hz. This frequency can be controlled by a variable potentiometer. The output from this unit would be connected to the step input on the stepping motor controller. (If more control is needed such as micro-stepping of the motor, then a micro-stepping drive is required, and the square wave generator will have to have an increased frequency range to accomodate the increased number of pulses for micro-stepping.)
The direction or rotation of the pump/motor combination would be controlled by a logic level of 5 volts or 0 volts to the direction pin of the controller. This could be accomplished by a single pole double throw switch with the common connection of the switch made to the controller and one side of the switch made to 5 volts and the other side to 0 volts. Flipping switch changes direction.
The stepping motor controller can be purchased in kit form. You will have to verify that whatever controller you use can handle the stepper motor current which I believe is 1.5 Amps. One will also have to limit the max current to the 1.5 Amp value. I would recommend a 24 Vdc power supply for the controller.
There are several suppliers of these kits which advertise here on CNCZone. You can also do an internet search for Stepping Motor Kits.
Hope this helps.
Jerry
[IMG] code is Off
Powermax 2 crow General Electronics Discussion 1 04-02-2004 11:09 PM
Powermax II stepper help? fyffe555 DIY-CNC Router Table Machines 14 09-05-2003 01:33 PM
Powermax II stepper help? fyffe555 General Electronics Discussion 2 08-07-2003 07:22 AM
