| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
Hi, I have a 6 wire 1.8deg/step Sanyo Denki DC stepper motor with the current and voltage ratings as follows: rated voltage : 5.4v rated current : 1.5A The problem is Im a rookie with this stepper stuff and purchased this motor from a scrap market...So there is no documentation available and now i wish to check whether the motor is in working condition.... Can anyone help out here...Is it possible to check whether the motors are in running state or not using only a battery(say 3V) ? If not what am i supposed to do ? Thx Last edited by junior85; 01-26-2007 at 06:47 AM. |
| You can not run a stepper with a battery. You need to commutate the field coils and that requires a "driver card" or IC of some kind. What to do? Research the subject of stepper motor driver's a bit more on this website or via Google. You might also look up L297 and L298 IC's as these are elementary stepper driver IC's. They'll at least get you started.... |
| Actually for test purposes you can rig up a single battery and four switches and provide the logic switching in order to step the motor, you may require a resistor in series with the centre tap of each set of coils to limit the current, depending on what battery voltage you use to limit the current in your case to 1.5amps. You can sequence the switches in the right order and get rotation. I can post the sequence if you cannot find it. Al.
| can you then create a 4 lobe camshaft over the switches, and rotate the motor by cranking the cam? Id love to see a picture of that. Hey maybe you could power the cam WITH the motor LOL
__________________ Lemon Curry?? |
| The attached file shows four switches to enable half stepping, otherwise you could use two switches that have a NO & NC contact. Al.
| connect the 6 wire together and rotate the shaft by hand if the shaft get freeze that mean ok Sanyo Denki data sheet http://www.sanyo-denki.com/Products/...rs/2-phase.htm |
| hey all Thx for ur response.... I found something myself the day I posted .... And yes as Al the Man said the motor can be tested using a Battery and resistors . U can find information related to the topic here Further i found a very simple driving circuit too using just IC and the parallel port... u can find it here But now i have another problem..I have to develop code to generate G codes for (milling/drilling/routing purpose) from an AutoCAD drawing. Pls advice where n how to begin ? I have started reading about AutoLisp coding...but i have heard abt ObjectARX which suposedly allows coding in C/C++ ... I need advice n help in this regard and also information regarding which forum to post in abt this issue.. Thx again for all the time u all put in to answer my query. Take Care Bye |
#11
To use this method I believe you will also need a Capacitor to produce a split phase to run as a synchronous motor on 1 phase. Al.
#12
| Yes you are right, there is a bit of circuitry needed, but not a lot.
__________________ Motion Control Products Ltd www.motioncontrolproducts.co.uk |
| Stepper Motors | OG Style | Stepper Motors and Drives | 0 | 08-25-2006 03:38 PM |
| stepper motors for X1... which ones? | ultravinnie | Benchtop Machines | 0 | 02-02-2006 01:48 PM |
| How hot do your stepper motors get? | klick0 | Stepper Motors and Drives | 3 | 11-14-2005 10:08 PM |
| Stepper motors in the UK. | Kammo1 | Stepper Motors and Drives | 0 | 07-05-2005 04:29 PM |
| Stepper motors... | Mikael | Stepper Motors and Drives | 4 | 09-14-2004 04:41 PM |
