Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-24-2007, 02:00 PM
miro is on a distinguished road
parallel vs series
Can anyone tell me should I go for 4, 6 or 8 wire steppers for a given torque. What can I gain from wiring 6 and 8 steppers in parallel bipolar or series bipolar comparing to 4 wire stepper.
Old 01-24-2007, 04:09 PM
Silver Member
mcpltd is on a distinguished road
6 Wire is unipolar or bipolar 4 wire series. (Full coil or half coil)
Full coil is good for for slow speed and half coil is good for high speeds.
Unipolar will give a lower performance than bipolar.
Series is good if you want high torque at low speeds, but the torque will drop of fast at higher speed.
Parallel is low torque at low speeds, but the torque does not drop off as quick as series, so is far better if you are running the motor fast.
Motion Control Products Ltd
www.motioncontrolproducts.co.uk
Old 01-24-2007, 05:01 PM
OK, but what about eight wire steppers, what bothers me is the diference between half coil connected 6 wire stepper and 8 wire parallel conected stepper. Firstly I understood that this is the same thing, but now I am looking at Stepper motor basics by Gecko and it seems to me like a complete two diferent things. Or am I missing something
Old 01-25-2007, 10:52 AM
jeffs555's Avatar
jeffs555 is on a distinguished road
With 8 wire parallel, you can generally increase the current to 1.4 times the half coil current. This would give 1.4 times the static torque.
[IMG] code is Off
Series/Parallel Bipolar steppers chas Stepper Motors and Drives 2 09-08-2004 01:06 AM
Series/Parallel Bipolar chas DIY-CNC Router Table Machines 0 09-01-2004 01:38 AM
What is a series and parallel circuit? ynneb DIY-CNC Router Table Machines 0 04-27-2004 09:58 PM
series or parallel turmite General Electronics Discussion 5 12-28-2003 10:27 PM
