01-20-2007, 05:44 AM
Simple Current Limiting Chopper Circuit??? | | I’ve looked everywhere but can’t find a practical chopper circuit to limit the current in straightforward unipolar drive circuit.
I’m using 8 discrete transistors (BD912) to drive a rated 4v 2.2A stepper on the x-axis and rated 4v 1.1A stepper on the y-axis of my first CNC machine (I’m new to this hobby!). I’m going to run these off a 24v supply, but obviously need to limit the current to the rated values, and rather than a wasteful current limiting resistor, a simple chopper circuit built entirely in hardware is the way to go. I don’t want to have to buy a stepper driver system from someone else, nor do I want to use an interpolator IC and driver combination with Vsense lines for chopping.
My present driver (assembled onto veroboard) uses four lines from a PC’s parallel port for each motor, individually controlling each coil of the motor (software can full and half-step). I’ve tested this with low voltages across the steppers and it works happily, so I just need to add the current limiting chopper circuit. There’s already a NOT gate on each of the lines from the PC (active low) to the drive transistors (active high) so I figured I’d be changing this for a NOR gate to allow the transistor to be turned on and off using the presence of a logic signal coming from a comparator (I had the LM358/LM324 in mind configured off a single+5v supply) which simply monitors the voltage across the motor coil and compares with a reference voltage. I’m not sure where to go from here though! Attached is a schematic I’ve drawn up in ‘crocodile clips’ showing the conceptual circuit I have in mind for each channel of the unipolar drive (since I’ll be half stepping, there’ll need to be a current sensing resistor on each channel). Has anyone got details of a successful practical circuit along these lines? (I’m sure there’s lots more needed than just this, particularly in terms of the comparator to TTL interfacing).
Use of oscillators or PWM seems a little overkill, but maybe a simple time-decaying RC timing circuit or op-amp feedback configuration to give some hysteresis would improve performance? Any ideas and comments would be much appreciated!
