Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-13-2007, 10:54 AM
KrashKing405 is on a distinguished road
Stepper ID?
I need some help getting info on this stepper [photo attached]. It has 5 wires, says it is DV24V 0.32A 1.8deg/step. Made by Toshiba. has HPM-215-24A on one part of the sticker, and FH7-1342 CLASS E lower down. Anyone have any ideas, or a place [other than google] to start looking??
Old 01-21-2007, 05:00 PM
hesham morsy's Avatar
hesham morsy is on a distinguished road
try thes
Javascript Page to determine stepper wires
http://www.piclist.com/techref/io/stepper/wires.asp
Old 01-22-2007, 05:36 PM
Thanks for the info, was looking more for something that would hsve a spec sheet for it. Will use that web page for sure though.
Old 01-22-2007, 07:50 PM
Ok, sorry for the double post here. That webage was not much help. The stepper has 5 leads. I did part 1, sent me to part 2, all connections had "dentents", gave me an error saying I did it wrong, that it only works for bipolar motors. Went back to test again, same result. Must be a unipolar then.
Old 01-22-2007, 11:25 PM
do not ask me for translation i m from Egypt
http://www.hobbycnc.hu/CNC/Motor/Motor.htm
47.
Típus: Toshiba HPM-215-24A (JAPAN)
- Tekercsrendszer: két fázisú, Unipoláris (5 kivezetéses)!!!
- Lépés: 1.8°/Step
- Feszültség: 24V=
- Áram: 0.32A
- Tekercs ellenállása: 5x75 Ohm/fázis
- Súlya: ~0.4kg
- Motortengely átmérője: 6.4 mm
- Felfogó csavartávolságok: 4x47mm (M5 menetelt)
Old 01-23-2007, 05:45 PM
Oh my god, you rock man! THANKS!
[IMG] code is Off
