Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-03-2007, 01:08 PM
ww_kayak's Avatar
ww_kayak is on a distinguished road
Stepper Motor: Pictures of Internals
I'm sure most of the people on this forum have an understanding of these motors, but I thought I'd post some pics, for newbs like me, of an Epson Stylus motor that I took apart. Having these to look at made it easier to understand all of the stepper motor articles I've been reading. I'm sure there are similar pictures on the site already, but sometimes there is just too much info !-) Anyway, I just wanted to start to contribute :-)
ID:	28441   Click image for larger version
ID:	28442   Click image for larger version
ID:	28443   Click image for larger version
ID:	28448   Click image for larger version
ID:	28449   Click image for larger version
ID:	28450   Click image for larger version
in order to learn... not save money.
Old 01-03-2007, 01:35 PM
Gold Member
InspirationTool is on a distinguished road
I was wondering how the stack of plates worked in the equation.
Thanks!
-Jeff
Old 01-03-2007, 02:50 PM
jeffs555's Avatar
jeffs555 is on a distinguished road
Thanks for the good pictures. You probably know, but for others who don't, disassembling a stepper motor is a bad idea if you plan to use it again. Removing the rotor from the stator can demagnetize it and greatly reduce the available torque.
As for the plates; most motors, transformers, and iron core inductors are built up from thin plates insulated from each other. This reduces the eddy current losses which consume power and generate heat.
Old 01-03-2007, 03:10 PM
rally.sport is on a distinguished road
hi
well ive takne mine apart today to sort out a problem
in my motors (large industrial ones) they have 4 segments on the centre shaft and they seem to be getting pulled along it until they all of the central drive peg, all 4 move along together but once one falls off the drive stops
any ideas anyone?
thanks
james
Old 01-03-2007, 03:28 PM
thkoutsidthebox's Avatar
thkoutsidthebox is on a distinguished road
Cheers
Hi kayak,
Great first contribution. I've been drifting around this forum for almost a year now and have never seen the inside of a stepper, until now!
What are the ridges/grooves shown in your 7th picture for? (Attached below)
Old 01-03-2007, 09:34 PM
ww_kayak's Avatar
Ya Jeff, I wasn't too worried about hurting it, I didn't really plan on using it for anything (too wimpy), but it was a good learning experience. I was able to write(basically copy) a small program and hook it up to my Linux box's parallel port and got it to turn in wave, full, and half step mode. Simple, yet... "WOW, THAT'S COOL!"
Like I said, I'm a newb, but I assume they localize the magnetic fields, or maybe simply bring them closer in those critical locations. I'm sure somebody here would know better than I.
Old 01-04-2007, 11:09 AM
pastera is on a distinguished road
The teeth create local maxima/minima allowing the motor to act as if it had many more poles than physically present. If you look closely hte teeth are offset from each other such that the teeth on the rotor can only align with a single set on the stator.
Aaron
Old 01-04-2007, 04:05 PM
FPV_GTp is on a distinguished road
hi
Kayak nice pics , as i have asked and search several times in here has anyone any idea what a stepper motor or servo motor looks like inside
do you have more pics ?
cheers
Old 01-04-2007, 04:54 PM
ww_kayak's Avatar
So, where does the offset between the upper and lower stators(disks?) fit into the equation? Does that only come into play in certain modes? (half-step, micro, ...)
FPV, that's the only motor I have, but I love to take pics, so if I find anything else of interst I'll rip it apart and take pics
[IMG] code is Off
