Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-01-2007, 07:23 AM
Daffy is on a distinguished road
Choosing a stepper motor
I'm looking for a stepper capable of driving a X,Y,Z axes for a table that could be like 100cm z-axis, 50cm x-axis, and what ever is necessary on the z-axis.
Would the one at the link be suitable?
It is 1.86Nm - 263Oz.
I could use 2 for the z-axis, and one each on the other axis.
I want my table to be able to handle both a dremel-like machine for aluminium and such, and a bigger wood-router-machine for wood-work..
Will this stepper handle the up and down direction (y-axis) ?
It is rated 4volts. Using a PWM controller board, how do I find the maximum voltage to feed this steppers..?
http://cgi.ebay.com/Nema-23-stepper-...QQcmdZViewItem
Old 01-12-2007, 06:14 PM
Oldmanandhistoy is on a distinguished road
Hi Daffy,
Unfortunately it is impossible to recommend a suitable stepper motor without a lot more information.
Gantry or moving table?
Weight of gantry or table?
Ballscrews, leadscrews or threaded rod and pitch?
What type of linear slides?
Required cutting speeds and rapids?
John
Old 01-12-2007, 07:00 PM
paulC is on a distinguished road
I agree with John in that there are a lot of variables to take into concideration.
It is more likely you would need 2 steppers on your x axis than the Z.
It should be possible to design a machine with these steppers but it depends on how fast you want to go and your budget for things such as ball screws.
And I would not look at a Dremel on a large machine. I made mounts for both a router and Dremel for my first machine and only used the Dremel once.
Paul
[IMG] code is Off
