Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 12-21-2006, 09:38 AM
Argofanatic is on a distinguished road
Gecko 203V or MCP's MSD556 ?
Hi, I can't descide what to buy to drive my pac-sci steppers (5.5A @ 35V).
Any pros and cons for these drivers, which one is a better choice?.
I am planning on buying a GRex to control everything.
Thanks,
Marc.
Old 12-21-2006, 10:13 AM
ger21's Avatar
The Gecko 203V is supposed to be indestructable, as far as wiring goes. Bad wiring can't kill it, bad motors can't kill it. Too much voltage can't kill it.
Old 12-21-2006, 01:09 PM
Silver Member
mcpltd is on a distinguished road
Our drivers also have over voltage and short circuit protection.
That is standard on most drivers.
Both drivers are about the same, but the MSD556 does have the edge on things like:
1) Higher resolution. (25600 over 2000)
2) Higher step rate (400Khz over 350 Khz)
3) No need for external resisters (all currents and resolutions are set with switches)
4) Optically isolated differential input signals.
If you can get away with 4.2A the MSD542 is a very good drive for the money (£33.00) about $66
Motion Control Products Ltd
www.motioncontrolproducts.co.uk
Old 12-21-2006, 06:42 PM
pminmo's Avatar
pminmo is on a distinguished road
I suspect the msd556 won't give you full power capability of your 5.5A motor. The rating is a peak rating, there was a long thread over peak ratings of MSD drives and their advertising here on the zone some month's back. You can search for.
Maybe I'm missing something, but there doesn't seem to be a manual online to view the setup procedure. There was at the time of that discussion.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 12-21-2006, 06:52 PM
Silver Member
All stepper drivers are rated peak, it is just we also reffer to the RMS figure as well.
The Gecko is rated peak, just like the msd range.
Marris confirmed that in the thread that you are reffering to.
Old 12-21-2006, 08:23 PM
Oldmanandhistoy is on a distinguished road
I have been using the MSD556 drivers for about a year now for approximately 4-8hrs/day
Set up 4.9 Amps PEAK and 42vdc.
In that time I did have one develop a fault which was replace within a reasonable amount of time. Other than that I have had no other problems.
Support via email and phone, I would say was very good.
Nothing else to add other than I am a happy customer and would buy from them again without hesitation.
Regards,
John
Old 12-22-2006, 04:06 AM
Thanks for the comments guys.
I think I'm leaning towards the MSD556.
I'm hopeing that 3 of these married to a GRex will drive my 10mm ball screws to CNC bliss.
P.S. Stay posted for my construction pics coming soon. I've got $2k worth of aluminum just waiting to be bolted together !
Marc.
Old 12-22-2006, 04:14 AM
Marc.
Good luck with your build and if you do buy the MSD556’s and have any probs setting things up (not suggesting you will) give me a shout and I will do my best to help or at least point you in the right direction .
Regards,
John
Old 12-22-2006, 09:13 AM
pminmo's Avatar
Where are your documents for the drive? Like we went through the last time, A G201 will run a 5.5A motor at full 5.5A, the mds556 will run it at 4A.
Old 12-22-2006, 09:46 AM
http://www.motioncontrolproducts.co....0datasheet.pdf
What is the peak rating for the G210?
Regards,
John
Old 12-22-2006, 09:56 AM
Silver Member
The Peak Rating of all the Gecko drivers is 7A
The Peak raging of our MSD556 is 5.6A.
Regards,
John
  #12   Ban this user!
Old 12-22-2006, 09:58 AM
Hmm, I remember reading the thread that you mention pminmo during my research.
I'm gonna need all the torque I can get, so I will need that extra 1.5 amps.
How about this, rather than using the MSD556 If I were to go with the MSD980 and configure it for 5.7A then I should get what I'm paying for ?
Marc.
[IMG] code is Off
