Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 11-27-2006, 10:57 AM
mpmarino is on a distinguished road
Info on Eastern Air Devices ??stepper??
Hi folks,
I'm just getting into this CNC stuff so pardon my ignorance please I'm a surplus junky and a scrounge, I like to keep my hobbies cheap - as does my wife. I have found some motors that I believe are steppers. If they can prove useful I could probably source a bunch of them, but if you could take a look I would appreciate it.
Label:
HYST SYN MOTOR
EASTERN AIR DEVICES
21V 173.3HZ 2PH .02HP
2.0A 10400RPM CLB
CONT DUTY
H34NHS-4
9732 08813
<end>
4 wire wh/r/bk/bl
1.3 ohm between wh/bk and between r/bl
It seems to be a stepper type motor when I play with a battery.... Thoughts??
Thanks,
Marc
Old 11-28-2006, 10:40 PM
OK, no takers
Lets try this....
does anyone think it's possibly a bipolar stepper?
it it possible to test without a controller?
thanks for reading..
Old 11-29-2006, 02:08 AM
coleong is on a distinguished road
Just an idea.
Maybe it is a synchronous motor from the description.
If you know where is it dismantle from, it will give you a basic idea what is the function of it.
Old 11-29-2006, 07:29 AM
Thanks for the reply!
Yes, I think is is a synchronous motor by the description as well. I notice a lot of steppers are called synchronous/stepper motors. It seems like it was used to control a prism in some sort of laser assembly.
The reason I persue this is that there are 100 or more that may be available at a very low price .
Old 11-30-2006, 10:52 AM
pastera is on a distinguished road
From the description of 10400RPM @ 173.3Hz thats a 2 pole synchronous motor, so I don't think you will be able to use them.
Most steppers cannot reach 10K RPM and are 200+ steps/rev.
Aaron
Old 11-30-2006, 10:59 AM
Thanks Aaron,
with that, I'll drop it and move on.
regards, Marc
[IMG] code is Off
