| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
I am designing a circuit board to control 4 unipolar stepper motors. I planned on using the Allegro 5804 but they are obsolete. I have looked into some of their newer chips but can’t find much info or application notes. I want this board to drive any motor from 9 volts to 24 volts or more and at least 1 amp. What unipolar stepper motor driver chips do you guys like and where can I find info and application notes for them? Meanwhile I am looking into a couple chips mentioned on this forum. |
The Allegro SLA7062M is a nice unipolar driver chip that I have used. The datasheet can be found here: www.techkits.com/SLA7062M.pdf Page 11 of the datasheet shows applications information. The chip can drive up to 3 Amps and will operate in half-step, quarter-step, eigth-step or sixteenth-step (microstepping) modes. It accepts simple step & direction signals so it will work fine with any parallel port breakout board. -Ed |
| Thanks Ed Do you know where I can find any sample application circuits that I can use as a starting point? That sense circuit wants an 0.1 to 2 ohm resistor. The only resistors I see at Digikey in that range are 5 watt. ???? It's only a sense input and 4 5 watt resistors take up a lot of real estate. I am a digital kind of guy and not an engineer. If I could find example circuits, I could adjust them to fit my needs. |
| Check out www.hobbycnc.com website - his "old" design uses the SLA7062M chip. I bought one of the 4 motor controllers and it works well for me (a mechanical guy - definitely not electronically oriented!) |
Clyde, The sense resistors carry the motor current which can be a maximum of 3 Amps. I use 0.3 Ohm, 3 Watt resistors. (Power dissipation = I*I*R) 3 x 3 x 0.3 = 2.7 Watts. So 3 Watt resistors are minimum, 5 Watt resistors will be even better. Mouser Electronics carries 0.3 Ohm, 3 Watt resistors. I understand the real estate issue, so I mount my resistors vertically. You can see a photo of my board here: http://www.techkits.com/industrial/index.htm -Ed |
