Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 10-08-2006, 03:58 PM
CNCezee is on a distinguished road
steppers VS Switch mode power
Hi Guys,
I have been looking around while building my router, and I have noticed a large degree of conversation about stepper power supplies.
100% of which are old fashioned linear rectifiers, transformer AC to DC conversion and a filter capacitor.
But no mention of switch-mode power supplies???????????
Any reason why?? because i have a real beauty 22.0 ~28.5 volts at 50 amps.
It woild be a real shame not to be able to use it
Roger
Old 10-09-2006, 09:45 PM
pastera is on a distinguished road
Most switchers a single quadrant units, meaning they cannot accept power from the load.
You would need to add a diode to block the motors from pumping the supply and a means of dumping the extra charge when deaccelerating the motors
Aaron
Old 10-10-2006, 06:55 AM
Thanks That is all i needed.
to look at my machine go to www.foundry-fopars.co.uk, and navigate to the CNC link.
Roger
Old 10-10-2006, 01:02 PM
jerber's Avatar
Gold Member
jerber is on a distinguished road
I use a 22-26V 10A switched supply buffered with two 10.000 uF capacitators on the ouptput. It works fine.
There's a document on http://www.geckodrive.com/support.cfm, called Step Motor Basics.pdf, wich says it's ok to use a swithed supply with a 2.000 -10.000 uF capacitator on the output terminal.
____________________________________
Jeroen
Old 10-10-2006, 01:25 PM
Many Thanks, I did notice once whilst testing the vast improvment on stepper preformance when a large cap was put accross the supply rails but i put this down to filtering and not dumpung power from the stepper.
In any case i will add both caps across motor supply terminals and accress the PSU.
Cheers Roger
[IMG] code is Off
