Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 08-30-2006, 06:40 AM
Greolt is on a distinguished road
How to set amps on driver?
Ok I read posts all about RMS an peak. Square wave moving to sinusoidal at higher RPM.
All went over my head
On the drives that came with a kit from China amp setting is done with a trimpot. Microsteping is set with dip switches
On Lou's sugestion I put my multimeter in series with one phase of a bipolar setup.
Then jog-stepped one microstep at a time till the amps peaked on that phase and adjusted the trimpot to the amps I wanted.
Is this the right way to do it?????
Next question
Repeated requests to China for info on the motors has been a waste of time.
No markings of any kind on the motors.
Looking on the Kellingnc website for motors that match the physical size and wire count I have come up with these assumptions.
Nema 34, eight wire, bipolar series, 3amps/phase
Nema 23, four wire, 3amps/phase
Does this sound like good assumptions or am I way off
Any clever people out there that can help me out will be much apreciated
Old 08-30-2006, 07:44 AM
ger21's Avatar
There's no way to guess the current rating based on size and wire count. I've seen PacSci motors of the same size and torque available with 6 different current ratings.
Old 08-30-2006, 07:59 AM
pminmo's Avatar
pminmo is on a distinguished road
You should have information with the drive as to how to set motor current. Usually there is a reference voltage that you adjust and measure via a simple dc voltmeter. You method has issues.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 08-30-2006, 03:24 PM
Thanks Gerry and Phil
I suspected that would be too simple.
I tracked down a PDF on the drive (thanks PatrickM) and this is all it had about setting amps.
"The driving current can be adjusted from 1.0A to 4.3A infinitely. The current will go down when clockwise rotate
the adjustable resistor; and the current will go up when counter-clockwise rotate the adjustable resistor."
Nothing else. What do you sugest?
Old 08-30-2006, 04:42 PM
pminmo's Avatar
Post the pdf, and maybe we can help.
Old 08-30-2006, 10:30 PM
Phil
The PDF is over the 2 meg limit.
I have read it through six times and the only mention of setting amps is exactly as I quoted.
It is very brief and written in Chinese-English. Looks more like a sales brochure than a tech document.
Thanks anyway, Greolt
Old 08-31-2006, 12:01 AM
James Newton's Avatar
James Newton is on a distinguished road
http://www.sxlist.com/techref/io/stepper/wires.asp may help figure out which wire is what. I would expect that some way of meauring the coils must be available that would allow one to compute the other ratings, but I don't know what it is.
Old 08-31-2006, 01:43 AM
James thanks for that.
I figured out the wires and have the motor connected and it goes no problem.
What I was hoping to do was set the amps to the correct level on the driver.
Mostly concerned about the first question.
Old 08-31-2006, 12:57 PM
pminmo's Avatar
There maybe be some clues even where it's not directly mentioned.
Old 08-31-2006, 05:05 PM
Phill
This is the link that Patrickm kindly provided for me to the PDF.
Should have remembered this when I first tried to upload the PDF
http://koeienuiers.nl/document_libra...otordriver.pdf
I am convinced that you won't find any thing helpfull but I would love to be shown up for a fool
Thanks for taking the time with this
  #11   Ban this user!
Old 08-31-2006, 07:29 PM
pminmo's Avatar
Well, I can't see it either. I'd contact the mfg.
  #12   Ban this user!
Old 08-31-2006, 08:15 PM
Well that's my problem isn't it I've asked the manufacturer for this info on so
many occasions that it appears hopeless.
Thanks again for taking the time Phill. I appreciate it.
[IMG] code is Off
