| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
| Stepper question: torque re: current Pacific Scientific PowerMaxII M21NXXA* Nema 23 8-lead stepper motors can be connected as: Unipolar (100 oz-in at rated 4.0A/phase, 0.46ohm ph resistance) Bipolar series (142 oz-in at rated 2.8A/phase, 0.92ohm ph resistance) or Bipolar parallel (142 oz-in at rated 5.6A/phase, 0.23 ph resistance) I'm happy that the lowest-possible current (2.8A/phase = 5.6A/motor) still gives the highest-possible torque. I can understand how wiring the half-coils in a phase in parallel doubles the current drawn. I can't understand why doubling the rated current doesn't increase the torque. I'm led to ask, "Why would anyone wire this thing to draw more current (unipolar or bipolar parallel) for same torque or even less? I suspect the higher currents might have better speed-torque curves, meaning slower torque falloff at higher speeds?
__________________ -- Dan |
| Hmm... A very good question, unfortunately still unanswered. :frown: I will look around elsewhere and here on the forum, because i'm still confused about a couple of things. The question mentioned above was one of them. Good question! Keep it up! Ed.
__________________ Not the horse, of course of course... Building my own Scrapheap challenge CNC, or is it Junkyard wars CNC? |
| I can't explain why off hand, but I can tell you that you're right. Bipolar parallel will give much better high speed torque, and sometimes a little less low speed torque, than Bipolar parallel. I believe it has to do with the inductance. RUnning you're motors bipolar parallel gives you a wider operating speed range, as bipolar series wired motors have torque curves that drop very fast.
| This is a good question. I understand that Unipolar and Bipolar Half Coil uses the least number of coils active so it doesn't give great low speed torque. Because of the short(er) length of wire involved there's relatively low inductance so the torque lasts at higher speeds because the motor is able to turn faster, quicker for a given power. Bipolar Series uses two coils in series (also the full coil depending on how many wires you've got) and so has very good low speed torque, higher than unipolar or bipolar half coil. Bipolar Series, two coils in series (or the full coil) has higher inductance than unipolar or bipolar half coil. High inductance means the torque drops off rapidly as speed increases. Bipolar Parallel uses two coils in parallel ( or the full coil - in parallel !) and so has good low speed torque like Bipolar Series. But the inductance is roughly the same as Unipolar or Bipolar Series because the effective coil length is one coil, the same as Unipolar and half that of Bipolar Series. That means the torque is also lasts through to higher speeds. The current per phase can be confusing and you need to consider how many/much coils are active in each drive method. Higher inductance basically means the motor is slower to energise each coil. As the step rate increases the motor is required to energise coils faster, the coils inductance increasingly works against this so the average power used over the time the coil is energised is less and so the torque is reduced. Increasing voltages works to counter inductance and increase the average power used by a coil by quickening the time taken to get to the rated amperage. This is why drivers using resistors to limit current, as opposed to choppers are slower than choppers for the same volts and amps. As a quantitative measure my machine runs far better with bipolar parallel than the other methods, to the extent that microstepping unipolar lost steps badly. Bipolar series ran well on microstepping but only at slower speeds, lost steps at higher step rates. Bipolar parallel works great with microstepping and with about 1.8 times faster g00's. As you used a Pacsci motor as an example I'll mention I got best response with mine by having as high a voltage as the driver would stand (48v) and not necessarily the all the rated Amps. Not providing the full amps means theoretically that you're not getting the full torque, but in real terms I found that wasn't much of an issue as having the motor respond faster and not loose steps over a wider range made the machine run better. Bipolar parallel gave a much wider 'sweet spot' operating range. Hope that makes sense. YMMV. |
| Think of power and not just current. Power is like the light bulb ahead, it tells you how much work is being done like a light bulb rating tells you how much light it produces. Wiring in series/parallel wouldn't matter if you could deliver the same power. However, if you have lower volts then parallel makes more sense and if you have extra voltage then series makes more sense. (this is assuming that you're using a PWM controller to control the current and not resistors although the example still works) The inductance of the coils will rise with RPM. This rise reduces the current flowing and is why the torque falls off with RPM and why the RPM is limited. All electric motors do this, its just a question of what RPM and steppers are generally lower. Like everything, counter-examples to generalities exist but its more a matter of matching your power-supply to the wiring than anything else. Cliff |
1) Serial Bipolar operations. One phase inductance Ls=2L and phase current = I = 2.8A We can find the storaged energy in the inductance. W = 0.5 * L * i^2 = 0.5 * 2*L * 2.8 * 2.8 = 7.84 * L 2) Parallel Bipolar operations. One phase inductance Lp=L/2 and phase current = 2*I = 5.6A We can find the storaged energy in the inductance. W = 0.5 * L * 0.5 * i^2 = 0.5 * 0.5 * L * 5.6 * 5.6 = 7.84 * L You can see we find same results. Last edited by bunalmis; 08-12-2004 at 03:18 AM. |
| I got this graph in an Oriental Motor newsletter. It illustrates it pretty well. Graph - Speed vs Torque Chris |
| Another way to look at it is to think of the magnetic force developed by the coil. In a motor designed for unipolar use ( a six wire motor) you can saturate the iron core magnetically at rated current with a single coil. This will give you max torque. Any more current gains you nothing, as te iron core can not generate a stronger magnetic field (and thus torque). Could even demagnetise things if taken to extremes. If you were to wire that six wire motor in bipolar series (isolating the center taps), you have twice the coil windings acting on the core, so you only need 0.7x (1/root 2) the current to saturate the cores. The doubled number of coil windings increases the inductance, so the coil and iron core will resist changes in current. (Every step is a change in current to the coils). This make for a steep torque curve, with torque reducing rapidly with RPM. An eight wire bipolar motor is designed to saturate the core with two coils on. That is why you will get a higher max torque rating for Bipolar as opposed to unipolar with an eight wire motor. In bipolar series it acts just like the six wire with the center taps isolated above. In bipolar parallel, you have two parallel paths for the current and the inductance is reduced. The coil and core resists changes in current less, meaning the motor can step faster. At the end of the day the rated torque is holding torque when the machine is stationary. Not very useful. Far more useful is torque at higher speeds to give good rapid traverses. This is achieved by running the lowest inductance motors for your drives current, at the highest voltage your driver can survive (for a choppering driver).
__________________ Regards, Mark www.wrathall.com |
#10
| How do the different modes effect holding torque? Ie; when the coil(s) are staticlly energised. Chris |
#11
| My questions have been answered I searched a bit through the forum and was pointed towards this link : http://209.41.165.153/stepper/Tutorials/Tutorials.htm I found it very helpfull and in fact it answered all my questions. Referring to the very first posting in this thread : Using the centre tap and either one of the two other connections in a 6 wire motor will result in higher speeds but lower torques. Not using the centre tap, but only using the two other leads, results in lower speeds but at the same time higher torques. Users with 8 wire steppers have more wires (configurations) to choose from, but with similar outcome. Ehh, right...Just read the tutorial mentioned above and you'll know what i mean Thanks everybody. Ed.
__________________ Not the horse, of course of course... Building my own Scrapheap challenge CNC, or is it Junkyard wars CNC? Last edited by Mr.Ed; 08-12-2004 at 05:27 PM. |
#12
| The torque difference running a unipolar motor bipolar halfwinding or bipolar series is only about 3% of holding torque acording to Marriss. As soon as the thing is moving the halfwinding driven motor gives greater torque.
| (possibly stupid) stepper question | anthony | Stepper Motors and Drives | 1 | 05-03-2005 11:07 PM |
| Stepper Motor High Torque Low Amp | Sanghera | Stepper Motors and Drives | 13 | 03-21-2005 07:16 PM |
| 2A current for 1.25A stepper | ACME | Stepper Motors and Drives | 3 | 08-31-2004 04:18 AM |
| Which stepper motor should I buy | Graham S | FAQ of CNC Machine building | 0 | 08-27-2004 06:58 AM |
| Stepper motor spec' source & question | Damachine | DIY-CNC Router Table Machines | 4 | 04-06-2004 02:01 PM |
