| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
| Just a few things I'd like to check, so here goes: 1. If the motor is rated 8.4V, what voltage should I supply it in order to use it effectively? 2. Is 425 oz.in (holding torque) sufficient to mill mild steel and aluminum with a max cutting area of 2x2ft (60x60cm)? (Assume threaded bolt and skate bearings...) 3. What's the difference between bipolar(series) and bipolar(parallel)? Which is best? 4. In terms of EM interference, will I be making things better or worse by using coiled wire chords (similar to those found on telephones) between my steppers and the drivers? My most humble apologies if these questions have been answered elsewhere; I'm not afraid of reading, so please just point me in the right direction!
__________________ snooper's second law: common sense isn't as common as we're led to believe... |
BTW there was a previous post where I got the information on how to custom coil your own cable, by coiling it around a former and heating in an oven to change its memory! It worked. I was finding it hard to obtain the type I wanted. You need a higher gauge than is required for normal motor current when using track or festoon, as the cable is constantly flexing. Cat5 is made for Ethernet use, not servo motors. Al.
| NC CAMS and Al, thanks to both of you; it's people like you (that take the time to answer noob questions and point us in the right direction) that not only contributes to this hobby, but to mankind as well. Thanks a million.
