Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 07-03-2006, 07:49 AM
curtisturner is on a distinguished road
Question Major lack of torque with steppers
I am having trouble with a new setup I am using the following:
2 680oz Torque Bipolar Steppers
Belt driven axis
36 Volt / 2.5 Amp Power / Controller (1 for each axis)
Mach 3
Everthing works OK, however with a 1 finger I can easily stop either axis.
Even with a low feed rate and low speed I could easily stall either axis.
HELP, this cant be right I know 680oz means holding torque, but when moving a meager 30 rpm it should have more than a couple oz of torque right ?
Thanks in advance.
Curtis-
Old 07-03-2006, 08:48 AM
jerber's Avatar
Gold Member
jerber is on a distinguished road
What drivers are you using ?
Torque is related to the current, maybe the current is limited some way.
Is there a way to adjust it ?
Is the 2.5 Amp for one phase of the stepper or is it for both phases ?
If it's for both phases then I think it's to small for a 680oz/in stepper.
At 30 rpm you should have plenty of power.
Jeroen
____________________________________
Jeroen
Old 07-03-2006, 09:03 AM
ger21's Avatar
What is the voltage and current ratings of the motors, and what drives are you using?
Old 07-03-2006, 09:10 AM
The drivers are built into the power supply (JTENG)
I am not sure if it is per phase or not, there is an adjustment that goes from 0 to 2.5A
I turned it the whole way to 2.5.
I did want to add 1 more thing, when it is not turning I can turn the pulley by hand with only a mild ammount of resistence not 680 oz by any means.
I also wanted to ask because I read it in one of the forums could it be a bad parallel port? That does not add up in my mind but what do I know!
Curtis-
Old 07-03-2006, 06:23 PM
ger21's Avatar
Do you have a link to the drive manufacturer? Or specs on it?
It's not likely the parallel port. A drive should lock the motors when powered up whether or not it's connected to the parallel port.
Old 07-03-2006, 06:59 PM
pminmo's Avatar
pminmo is on a distinguished road
Unless the 680oz motors are rated for a much higher current?
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 07-04-2006, 09:55 AM
The motors are rated at 2.8 amps / PH , I could not find t he voltage rating
These were mated by the manufacturer, and were bought a month ago brand new.
Curtis-
Old 07-04-2006, 02:49 PM
pminmo's Avatar
At 2.5A on a 2.8A motor you shouuld have gobs of power. Still need info on the motor driver. i.e. electronics that hooks up to the motor. Maybe a picture?
Old 07-04-2006, 03:52 PM
OK, I dug up some more info
http://www.j-teng.com/STP-DRV-35025.pdf
http://www.j-teng.com/images/27_1_b_150x145.jpeg
More Motor Info
2 Phase
DEG/STEP 1.8
Volts 5
Amps / PH 2.8
Ohms 1.8
mH 18
Oz Torque 680
Curtis
Old 07-04-2006, 04:07 PM
pminmo's Avatar
measure your DC voltage on each driver to see what it is, I suspect you may not have you AC transformer wiring configured correctly and are getting a low DC motor supply voltage, thus no power.
Out of curiosity, why can't your driver supplier support you?
Old 07-04-2006, 05:02 PM
Silver Member
mcpltd is on a distinguished road
Also 2.5A rating for the driver is 1.76A RMS so if your motors are rated in RMS you will only get just over half the torque.
(Motors are normally rated RMS)
Also are the you connecting in series or Parallel?
Motion Control Products Ltd
www.motioncontrolproducts.co.uk
  #12   Ban this user!
Old 07-04-2006, 06:12 PM
pminmo's Avatar
[QUOTE=mcpltd]Also 2.5A rating for the driver is 1.76A RMS so if your motors are rated in RMS you will only get just over half the torque.
[QUOTE]
In full step mode true, but that will be the case for many, many microstepping drivers. (BUT NOT ALL )
Still should have more power than described.
[IMG] code is Off
