Results 1 to 7 of 7
Thread: Hobbycnc kit
    Mar 2006
    Hobbycnc kit
    Does anyone have any opinion or have this hobbycnc set up for motors and a driver? What are the pro's and con's of uni-polar vs. bi-polar stepper motor?
    4 Axis 4AUPC Kit + (4) 200oz-in, 3v, 3A
    Dual Shaft Steppers
    $279USD + $19 USA S/H
    http://www.hobbycnc.com/4aupc.php
    Dan Furlano
    Mar 2006
    What do you intend to use the motors for? Unipolar = more speed less torque and bipolar = more torque and less speed. Its a good price for what you get.
    If it doesn't work BUY BIGGER MOTORS!!
    www.joescnc.com joecnc2006's Avatar
    Aug 2004
    Quote Originally Posted by dfurlano
    Dual Shaft Steppers
    Dan Furlano
    Thats the Kit I use on my machine and works fine, cutting at 80ipm.
    Joe's CNC Model 2006
    Joe
    Mar 2006
    Forgot to say that I would like to use it on a Grizzly 8689 mini mill.
    Mar 2006
    That kit and motors would work just fine on that mill. Make sure you buy a good power supply capable of supplying between 24-40 volts for best motor performance. It is easiest to make one using a transfomer and capacitor.
    Mar 2006
    I asked Hobbycnc about this kit on a mini mill and his reply was that is it too small and I need at least 300oz motors which they do not sell.
    Mar 2004
    Iowa, USA
    Try Keling Inc. I run their steppers. Very strong and decent prices. You will want to do some comparisons and look for 6 or 8 wire steppers to use with HobbyCNC. They have a Nema 23 8 wire that will get around 300 oz/in at 2 amps in unipolar mode. Model KL23H286-20-8B. Drive it with 24volts or better, prefer mid 30s VDC.
    The last number and letter of the part number is the wire count and A for single shaft, B for dual shaft.
    www.kelinginc.net
    RipperSoftware
  • Posting Permissions
