Results 1 to 6 of 6
Thread: What do the step and direction pulses do?
    Jun 2005
    A friend of mine is building a stepper driver, writing his own program for a PIC.
    He needs to nkow about step and direction. I would not mind knowing either...
    What exactly does it 'tell' the motor? Can somebody give a breakdown of what these pulses do, is it change direction or what? I will give more specific questions in a few hours when I see him again
    Aug 2004
    Greece
    Quote Originally Posted by phantomcow2
    It doesn't tell the motor anything, it's aimed to the controller. The controller has to change the polarity on the motor's windings to make it move.
    Assuming a unipolar drive, a sequence like this is needed to move it on one direction:
    1000
    0100
    0010
    0001
    or for halfstepping:
    1100
    0110
    0011
    1001
    For turning the other way the sequence must be reversed. So whenever the controller receives a step signal while the direction pin is high it should move the motor in the next step of the sequence, if the direction is low to the previous.
    What the controller will do from there depends on the type of motor it has to control (unipolar/ bipolar) and the step type (full/ half etc).
    Nikolas
    Jun 2005
    Alright I hvae a specific question now.
    What does the direction pulse going into the driver look like?
    Registered WayneHill's Avatar
    Mar 2004
    Michigan
    I thought this was half step sequence.
    1000
    1100
    0100
    0110
    0010
    0011
    0001
    1001
    Wayne Hill
    Mar 2004
    Michigan
    For steppers, the pulse step sequences the direction.
    (Could be wrong here. I'll let the experts weight in on this one.)
    Direction 1
    1000
    1100
    0100
    0110
    0010
    0011
    0001
    1001
    Direction 2
    1001
    0001
    0011
    0010
    0110
    0100
    1100
    1000
    Wayne Hill
    Mar 2004
    Michigan
    Check this out. PIC program for step and direction.
    http://www.dakeng.com/u2.html
    Wayne Hill
  • Posting Permissions
