Results 1 to 1 of 1
Thread: Help for best motor current set up
    Apr 2005
    ITALY
    Hi to all
    > could anyone me confirm if the following considerations are correct regarding my application with the G201 driver?
    > My hardware is:
    > switch power supply, with 56 VCC, 5 A (for a total of 4 motors)
    > Sanyo-Denky step motor 103-H7126-0140 (the data sheet is attached)
    > PMDX-131
    > 4 G201 step drivers
    > Mach2/3 control SW
    > In bipolar series configuration I use a resistor of 28500 ohm (
    (47500*0.75)/(2-0.75) ), without jumper (in reduced current range); in this
    configuration I have some problems of resonance near to the 60% of the maximum speed (3000 mm/min; the resonance is not dumped by the driver)
    > In bipolar parallel configuration I use a resistor of 12954 ohm (
    (47500*(.75*2)/(7-(0.75*2) ) in normal driver operation range; any resonance problems but the motor don’t work so good (the max speed is to low); it work’s best with a 27000 ohm resistor, but I don’t understand why.
    > So, I have a little bit confusion on the value resistor calculation because I’m not sure if the amperage that I consider in the formula (0.75 for the bipolar mode) is correct for the best hardware performance.
    > Could anyone me suggest the best set-up with this hardware (or suggest witch could be the optimal configuration)?
    > There is a special set-up in Mach SW (when combined with the geko?)related to the Minimum Pulse With option and the Direction Precharge,?
    > There is a smart formula that can help me to calculate the torque related to the ampere that flow in the motor turns?!
    tanks to all
    Attached Thumbnails Attached Thumbnails Help for best motor current set up-15ita.pdf
