Is 24V enough? 6+6+21 amps is enough, i think. Acording to the Gecko manuals, you can drive servos at up to 25x the rated voltage or 57V. I see that Dan Mauch specs 36V supplies for similar steppers...
Wes,
The power supply would allow your system to operate, but you would be limited to lower feedrates than you could attain with a 36 Vdc or higher voltage.
I agree with Dan that your voltage should be AT LEAST 36 Volts.
I run my system on 48 Volts which causes the motors to heat excessively after 3-4 hours of continious operation, but not many hobby projects take that many hours, so in reality it is not a problem. I am recommending a voltage range of 36 to 48 Volts. That will give you more torque and higher feedrates.
Jerry
LinkBack URL
About LinkBacks
