Results 1 to 5 of 5
Thread: Help me please, strange vibration in z step motor
    Jan 2006
    Mexico
    Hi, i finished building my controllers cards and interface board in accordance with the diagrams in the book of Geoff Williams "CNC Robotics, build your own machine workshop", the problem is, when i put in the Kcam registered program, all the directions and setup timing, the step motors work really fine with enough torq, but only in the X, Y the Z one starts vibrating instead a normal movement, i checked the connections, the voltages, the port setup, the controller card in comparation with the other two and everything is identical, dont know whats happening.
    I pluged X and Y to a power supply, and the Z to another power supply alone, the strange thing is when i shut of the X and Y, the Z works perfectly, but when i turn on X, Y it makes again the same vibration, and when i reboot my machine again, the 3 motors works perfectly just for 3 minutes, after that time, the Z makes the same vibration, dont know what to do i checked and checked everything.
    One thing i noticed is when i squiz a little the paralel cable, the motors all them makes a little noise as if were going to move, but i have interchanged the cables and everything and i had make L297 and L298 interchange and nothing, the same happens.
    My PC is an old Pentium 200 MMX with 32 mb ram, hard disk 1 gb and win 98 SE, but is the PC??, is any interferance, what else the energ cant be becouse one power supply is only for z
    I tested in an dos program "cstep" thinking on the PC and the same, dont know what to do.
    Please give me any sugestion, ahh the Y card is the sync director.
    Jan 2005
    Toronto, Canada
    Check your grounding. Each axis should ideally have their own power and ground pin, going to the power filter cap.
    Registered thebackshed's Avatar
    Jan 2006
    Same problem with KCam
    I think I have the same problem with KCam. When the machine is routing on the level, the Z axis steps one step up and down approx every half second. I have leds on the port connections, and these are also changing for the Z axis only. I think this may be a software problem in KCam.
    Glenn
    Jan 2006
    Mexico
    I think solved problem
    Thanks for your help, i solved it by lowering the feed rate in z step and checked the ground connections, one of them, in a capacitor was weak i reinforced with new capacitors and new welding, and it helpéd, no vibration, only it appears when i try to level up speed in z, but z can be slow motioned, so i dont need as much speed as in x or y, i think that the problem was in the capacitors in my board, and in the kcam program running in my such old machine.
    Thanks for your helping.
    Jun 2006
    Slow computor
    I heard that 1000mHZ is a good threshold for windows based CNC.
    If you went DOS I think you would be close or within operating paramenters.
  • Posting Permissions
