Results 1 to 4 of 4
Thread: How to invert slave motor direction?
    Jul 2003
    Malaysia
    I am using two motors and two drivers for y-axis (master and slave), how to invert the slave motor direction againt the master motor by only using one signal pin from printer port to both drivers?
    SC
    Dec 2005
    Switch leads at one motor????
    Don't forget to switch leads appropriately at servo encoder if so equipped.
    Gold Member
    Mar 2003
    Swap motor leads on one winding only. Doesn't matter which one.
    Mariss
    Aug 2004
    Brazil
    If you are using along with CNC, may exist one parameter for make the inversion at CNC.Check that. Of course this is conditioned to the CNC model.
