Results 1 to 4 of 4
Thread: advice on voltage and amps to run higher RPM
    Dec 2011
    united states
    im using 3 425oz steppers with a 36v 10 amp power supply. my drivers are rated for 18-56 volts and up to 4 amps. currently im giving them 36vs and 2.15 amps per stepper motor.
    im not sure if these 425oz are able to go any faster. the fastest axis i have is the y axis using 8tpi. i can run it up to an inch per second. so thats 8 rps. sould this stepper motor be able to go faster than that? would upgrading the voltage or amperage make it run faster?
    UUU
    UUU is offline
    Apr 2010
    UK
    Generally speaking it's the amps that give you the torque and the volts gives you the speed. If all three drivers pulled 4 amps then you'd need 12, but it's normally understood that this doesn't happen, so your 10 amp supply seems OK. But you could use more volts - up to 56 - and you'd then get more speed.
    I normally think of feed rate on a per-minute basis, so you're getting 60 inches per minute. It depends how big your machine is - mine is tiny, so I'm happy with a lot less than that.
    Oct 2004
    Generally you want to run at the steppers rated current and at a voltage equal to (32*(L^1/2)) where L is the steppers inductance in milliHenries. If this value is higher than the drive's max voltage then run at the drives max voltage. Be sure to read 'Step motor basics' on the support page for Geckodrive even if you're not using Gecko products. It's very instructive.
    To get more speed you might want to consider a higher lead screw. You're typically getting into the region of rapidly declining torque at 8 rps. Screws with 4TPI or 2TPI would give an improvement in speed though at the expense of resolution.
    Chris
    Jan 2005
    Toronto, Canada
    Doubling the voltage will double the speed. Increasing the current setting will probably increase your speed. Note, that you do not need to restrict the total current to 10 amps. Try setting the currents to 4 amps per motor and see if it's good enough. If not, get a higher voltage supply.
  1. Stepper Squeal/Whine at higher voltage ... So close, but yet so far
    By Johnsnd in forum General Electronics Discussion
    Last Post: 12-12-2010, 01:06 PM
  2. Able to run motor with higher voltage driver?
    By Syphonics in forum General Electronics Discussion
    Last Post: 04-21-2009, 09:49 PM
  3. Does higher voltage allow steppers to move faster?
    By SCCoupe in forum DIY CNC Router Table Machines
    Last Post: 03-21-2005, 12:27 PM
  4. Capacitor at higher voltage?
    By DAB_Design in forum Gecko Drives
    Last Post: 12-18-2004, 05:46 PM
  5. Howto find input amps, from output amps on transformer?
    By sendkeys in forum General Electronics Discussion
    Last Post: 07-14-2004, 08:13 PM
