If i was you i would check what power supply you have and the encoder drivers to see if they need upgrading, alternatively if you can't decide, settle for a "package" power supply, encoders drivers and stepper motors, you may find it could work out cheaper as a package. I would also consider if you are thinking of buying a new spindle motor check your "Z" depth and gantry stability with a bigger spindle motor attached. one other point buy a "aircraft grade" aluminium as you need a aluminium which "chips" this does'nt clog the cutter. hope this helps
LinkBack URL
About LinkBacks
