Results 1 to 3 of 3
Thread: auto reset problem in Mach3
    Feb 2011
    Ukraine
    During work the machine automatically stops the same way as if I pressed the emergency stop button on the control box!
    This happens many times during work and I can't figure it out why it is. Before, I have this problem if I connected the probe wire to my breakout board, then run the spindle (then the machine automatically was stopped working and I've had to press the reset button in mach3).
    If I did the probing without running the spindle, no problem of like happened. Is the breakout board getting a problem?
    What troubleshooting process I have to perform please?
    Mar 2003
    Shelby Twp, MI....USA
    You have noise triggering your estop or limit switches.
    Feb 2011
    Ukraine
    Quote Originally Posted by ger21 View Post
    Thanks, what should I do? to isolate control box from machine plate? (they are currently on 1 table), or known better methods exist?
  1. Pressing Reset in Mach3 set Machine coords to 0?
    By nova24 in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-21-2012, 10:21 AM
  2. reset en auto d'un fanuc
    By skidoo in forum Français CNCzone
    Last Post: 03-09-2009, 08:15 AM
  3. Mach3 reset defauts
    By Clot in forum Mach Software (ArtSoft software)
    Last Post: 04-22-2008, 07:52 PM
  4. Mach3 make reset after showing the 1st splash picture...???
    By ata in forum Mach Software (ArtSoft software)
    Last Post: 04-04-2007, 11:33 PM
  5. Mach3 External Estop Reset
    By bcromwell in forum Mach Software (ArtSoft software)
    Last Post: 01-24-2006, 11:16 PM
