Results 1 to 6 of 6
Thread: Wiring Q: Japan Servo Co. Stepper
    Apr 2011
    I'm retofitting a new controller on a rotary tool changer on a small CNC lathe. There is currently a Japan Servo CO. KH56QM2-801 stepper motor. 1.8 degrees per step, 3.15 volts.
    The strange thing is that there are six wires, but only four are used. It is a uni-polar stepper, with the following six wires:
    Red (used)
    Black (not used)
    White/Red (used
    Green (used)
    White (not used)
    White/Green (used)
    The stepper motor calls for this excitation sequence (which obviously can't be done if the Black wire and the White wire aren't used:
    Step: 1 2 3 4
    red : - -
    grn : - -
    w/r : - -
    w/g : - -
    b : + + + +
    w : + + + +
    So these are my two quesions:
    One: why is it being run without using either the black (b) or the white (w) wires?
    Two: what controller can I use to run the stepper? (I will be using Mach 3 Turn... it would be cool to have tool changing capability, but worst-case I would be okay with manually advancing the tools using a simple controller and a button)
    Thanks for your help!
    Registered doorknob's Avatar
    Jan 2010
    The excitation sequence that you have shown is intended for use with a unipolar driver that uses all 6 wires of the motor.
    You can hook up a 6-wire motor using only 4 wires and connect it to a bipolar driver. There are two different ways to hook it up using 4 of the six wires - either in "half-coil" or "full-coil" mode.
    See Support Figures 9 and 10 for a better explanation.
    From your description, it sounds like it is set up for the full-coil hookup (the winding center taps are not connected).
    Apr 2011
    Thanks for that information. Is it less expensive to control as a bi-polar setup? Can anyone recommend a controller?
    Jul 2011
    In principle unipolar setup is less expensive than bi-polar. In practice, only printers and scanners use the cost advantage of a lower cost driver IC.
    With Mach3 you are restricted to the use of the printer port, however, you can use a low cost 3-axis driver board from China (ebay) or more sophisticated Gecko driver, which is recommended by this site.
    I could not verify your part number. Is it 901 or indeed 801?
    Apr 2011
    Quote Originally Posted by stewi View Post
    I'm definitely going to use Geckos (as in my 3 axis mill / servos).
    I'm 99% sure it is the 801... the tag was a bit soiled but that appears to be it.
    Jul 2011
    1. Replies: 0
      Last Post: 11-14-2011, 03:40 PM
    2. Japan servo motor DS64BE40-2 Encoder wiring
      By dmauch in forum Servo Drives
      Last Post: 08-09-2011, 12:24 PM
    3. japan servo wiring diagram
      By norw1946 in forum Stepper Motors and Drives
      Last Post: 12-21-2006, 03:43 PM
    4. Japan Servo - Need Specs On Stepper
      By buildsumthin in forum Stepper Motors and Drives
      Last Post: 08-31-2005, 07:57 AM
