Results 1 to 10 of 10
Thread: tb6560 power
    Apr 2012
    uk
    tb6560 power
    I have a 3 axis tb6560 board . and wanted to know how to power the 12v power source for the board. is it just a 240v power source to the 12v ???
    Registered doorknob's Avatar
    Jan 2010
    You need a DC power supply - either regulated or unregulated should be OK.
    Such a power supply will take your 240 v AC line power and convert it to 12 volts DC.
    Depending on the characteristics of the motors that you will be using, you may want greater than 12 volts, but you may not want to go much more than 24 volts at the high end (although some people do).
    Apr 2012
    uk
    i have a 12v power supply for the board . but im unsure if i just get a plug straight from the mains and connect the live-neutral and earth to the 12volt box i have which came with the package i bought.
    Registered James Newton's Avatar
    May 2005
    Wouldn't that be a question for the people you bought the package from?
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Apr 2012
    uk
    it is and i have they just said look at the pic on ebay but thats no help.
    my 12v converter has:
    live - neutral -earth - com -com -com - +v - +v -+V so not sure as to how that all goes together in to the control board . ive looked online and cant find anything
    Jan 2010
    I'm somewhat hesitant to make a recommendation inasmuch as my direct knowledge of UK AC power wiring is limited to having once or twice plugged my electric shaver into the outlet in a London hotel room's bathroom.
    It was a very fine hotel with a very fine bathroom and a very fine outlet, and so I have fond memories of my time spent in London, as stressful as it was (due to the challenging business purpose behind several of the trips), but I will defer to someone closer to you to address UK electrical hookup questions.
    Registered john_100's Avatar
    Mar 2007
    uk
    Hi Denrow ,
    I would use two switches to control the mains supply to your switch mode power supply
    a two pole switch illuminated rocker switch (or rotary switch) as the main
    on /off switch
    also depending on the E stop switch you use
    1 or 2 normally closed switch contact(s) on your emergency stop switch
    as a Quicker and easier to use on /off switch
    and another switch contact to trigger an E stop to the control system
    switching just the live is OK but live and neutral is better
    for me , only having a software E stop is not good enough
    while an E stop ,when the control software is responding ,
    will stop the steppers quicker
    you need to remove the mains supply as well
    since the pc may have stopped responding
    you could have an over load due to a fauty power supply or stepper driver
    don't switch the DC supply to the stepper drive board
    that will damage the stepper IC's
    on the power supply ,the three common terminals are connected together
    and the three positve terminals are connected togerther
    this makes it easier to connect the 3 pairs of supply wires to three individual stepper drivers
    with the all in one board you only need to connect to
    one - common terminal and one positive terminal
    John
    Apr 2012
    uk
    Hi John
    Thanks very much for the help , its has been very useful.
    I was intending to put a rotary isolator switch from direct mains into dc convertor but the switch i have isnt straight foward . it has l1 & l2 on opposite sides of the switch and at the rear has earh (x2) and neutral (x2) as ive never come across these switches before its a bit of a problem have already asked guys at work and looked online for wiring diagram but cant seem to find one so i im thinking just a normal swich instead.
    Apr 2012
    uk
    Quote Originally Posted by doorknob View Post
    Doorknob -
    I in fact had the same issue when i visited Texas for a month , The hosts i stayed with found it quite funny at how huge our plugs were , thier said '' Where the hell is that ment to go'' when i told them it was a plug they found it funny as hell.
    Mar 2007
    uk
    Hi Denrow ,
    A picture of your switch may help some one to identify the switch terminals
    modern switches are usually made up of a number of sections
    each comprising of two switches that are forced open by the cam
    the two switches are wired as a single double throw switch
    yes the UK plugs are some what larger but for a good reason
    John
    PS for non UK forum members
    unlike the two pin shaver plugs ,the UK 13Amp plugs are fitted a 1" HRC fuse
    very often its a 3A , 5A or 13A to suit the appliance and its mains cable
    ( 1A, 2A, 7A and 10A fuses are also available)
    the 13A sockets are connected to a ring circuit thats protected by a 30A fuse or circuit breaker
    1. HobbyCNC will work with EMC2, but not Mach3
      By crane550 in forum Mach Mill
      Last Post: 02-15-2011, 09:02 AM
    2. EMC2 from Mach3 issues
      By bevins in forum LinuxCNC (formerly EMC2)
      Last Post: 02-13-2010, 02:06 AM
    3. Need Help!- Mach3 versus EMC2 subroutines
      By dynamotive in forum G-Code Programing
      Last Post: 08-25-2009, 09:17 PM
    4. TurboCNC vs Mach3 vs EMC2
      By JeLC in forum DIY CNC Router Table Machines
      Last Post: 03-01-2009, 01:46 PM
    5. EMC2 -vs- Mach3
      By spoiledbrat in forum LinuxCNC (formerly EMC2)
      Last Post: 06-10-2007, 06:18 PM
