Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: CW230 Driver board Help
    Dec 2011
    I recently got 3 of this driver board everything works great except that when I try to jog or move a long distance the stepper motor moves at the beginning and then stops and when is finishing it starts moving again. I dont know how to fix that I want the motor to move for the whole time I press the arrows keys here is a spec sheet of the drivers
    Stepperdriver40v3a.pdf - By Nitro PDF Software
    Jan 2005
    Toronto, Canada
    What is your velocity and accel set to? Try lowering the speed.
    Dec 2011
    Quote Originally Posted by H500 View Post
    Thanks it worked I set the steps to 2000 and the IPM to 100 and the pulses to 1
    Dec 2011
    Does anyone know what is the fastest ipm this will work
    Jan 2005
    Toronto, Canada
    It depends on your machine. Mine is set at 250.
    Dec 2011
    Can anyone help me set my driver with this driver board. I really would appreciate it also I dont know If I have all the info I need
    Here is the link
    http://www.savebase.com/infobase/dow...kout_board.pdf
    Jan 2005
    Toronto, Canada
    Perhaps you can write down what you plan to do. Then we can tell you if you're on the right track.
    Dec 2011
    I just want to know what is the correct way to wire the breakout board to my driver boards but also I dont know if I have all the info because in the manual of the board I dont see the input signals pins and a few extra stuff that other boards use on mach 3
    Jan 2005
    Toronto, Canada
    All you need are step and dir. The enable pin is needed on some boards. The limits are useful, but not absolutely necessary to get the motors moving.
    Dec 2011
    So all I need to do is wire the driver board to the step and direction, but what I dont know are the pins to configure in mach 3 because in the guide that show me how to set it, it does not say what are the input pins. Also thanks alot for your support I really appreciate it.
    Jan 2005
    Toronto, Canada
    Mach is completely configurable. Look under Config---Ports and pins.
    Dec 2011
    Ok so I got a new board but apparently my x axis is not working is there anyway I can get it to work or if I did something wrong here is the guide I used. I am new to this cnc stuff and really need help and help will be appreciated thanks.
    Attached Files Attached Files
  • Page 1 of 2 12 LastLast
    1. Newbie- Help with EMC2 timing for CW230 drivers?
      By kazoochips in forum LinuxCNC (formerly EMC2)
      Last Post: 05-23-2012, 10:11 PM
    2. Newbie- need help with CW230 driver timing for EMC2
      By kazoochips in forum Stepper Motors and Drives
      Last Post: 01-11-2012, 02:48 PM
    3. Need Help!- MicroStep CW230
      By achavarria in forum Controller & Computer Solutions
      Last Post: 11-01-2009, 09:36 AM
    4. Need Help!- Driver Board
      By belizewood in forum Teachers Hang out
      Last Post: 04-15-2009, 11:52 AM
    5. single axis driver and a b.o.b.,or multi-axis driver board
      By .xXACEXx. in forum Stepper Motors and Drives
      Last Post: 07-03-2007, 12:13 AM
