Answer is b. But try using the bipolar half coil configuration and set the current to 2 amps. It will likely give you higher speeds.
Hi everybody!
I'm a CNC newbie wanting to build a foam cutter. I have very little knowledge of eletronics, but a strong will!
Already bought some parts...
-TB6560 4 axis driver board (3A stepper drivers)
-Vexta PK266-02A 2 phase steppers (6 wires)
-24V 14.6A 350W switching power supply
...which I would like to test.
I guess the power supply is OK, but I'm not sure how to set DIP switches 1 and 2 (current) correctly for my steppers, and don't want to blow something away.
According to the stepper .pdf specs:
Current/phase = 2.0A for unipolar and 1.4A for bipolar.
Same specs recommend 24 Vdc 2.8A for bipolar and 4.0A for unipolar.
This is when I get confused, when trying to calculate current for driver settings:
a) Current = Current/phase * phases ? (4A unipolar - 2.8A bipolar)
or
b) Current = Current/phase ? (2A unipolar - 1.4A bipolar)
If answer is a) then I wouldn't be able to provide 4A because the driver supports 3A max (supposing unipolar connection)
If answer is b) then I would be OK with the driver current output, but should set DIP switch accordingly. In this case, I can only set 100%, 75%, 50%, 25% of 3A, which gives 3A, 2.25A, 1.5A and 0.75.
What setting should I use? 2.25A? 1.5A?
Perhaps I'm missing other information relevant to my question. If so, feel free to ask.
Any help will be appreciated.
Regards,
Martin
Thanks for your answer.
Using bipolar (series) connection the current requirement will be 1.4A, so setting 2A will not burn anything?
Nearest setting through DIP switches is 75% * 3A = 2.25A. Will this be OK?
Regards,
Martin
Bipolar parallel at 2.25a should be fine. If the motor is mounted on metal, a lot of heat would be conducted away. You could also use a small cpu fan if the motor gets too hot.
But don't put 2.25 into bipolar series. The motor will overheat.
Now I'm even more confused...
Specs at http://www.interinar.com/public_docs/PK266-02A.pdf say nothing about bipolar parallel connection. Only unipolar or bipolar series.
Is this possible?
I actually meant bipolar half coil. It has the same current rating as unipolar.
