Results 1 to 2 of 2
Thread: Steps setting
    Feb 2012
    England
    Steps setting
    how does one determine what to set the stepper motors step switches to?
    Registered KOC62's Avatar
    Mar 2009
    I'm assuming you are referring to micro-stepping.
    According to the Mach3 manual, microstepping is mainly used to reduce mechanical noise and possible resonance problem. Hence there is no specific answer to your question. If you go too high in microstepping then there will be an upper RPM achieveable due to the maximum kernel frequency of say Mach3, or EMC2.
    As an example, my Gecko G540 is fixed at 10 microstep setting.
  1. How setting tools and setting offset
    By John246 in forum Sharp CNC
    Last Post: 10-08-2012, 03:38 AM
  2. IH steps per
    By Runner4404spd in forum Industrial Hobbies (Support forum)
    Last Post: 10-25-2010, 09:34 AM
  3. difficulty setting steps per unit in mach3
    By Josh Leber in forum Machines running Mach Software
    Last Post: 08-04-2009, 05:57 AM
  4. Need Help!- Recommended 'steps' setting
    By bradtal in forum DIY CNC Router Table Machines
    Last Post: 08-29-2008, 01:04 PM
  5. Full Steps -vs- Micro Steps
    By DJB282000 in forum General Electronics Discussion
    Last Post: 12-29-2005, 12:25 AM
