Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: tb6560 vs G540 vs HobbyCNC
    Nov 2011
    I'm always wondering, how does the tb6560 compare to geckos and hobby Cnc boards?
    Registered bobsch's Avatar
    Oct 2008
    Quote Originally Posted by flojor10 View Post
    Sorry for straying off topic but I'm always wondering, how does the tb6560 compare to geckos and hobby Cnc boards?
    There is no comparison. tb6560 boards are the worst, Hobby CNC in the middle with Gecko at the top.
    That's my opinion anyway.
    Bob
    "Bad decisions make good stories."
    Nov 2011
    Quote Originally Posted by bobsch View Post
    Since the geckos and the tb6560 are both bipolar doesn't that make them better than the unipolar hobby Cnc board?
    Apr 2009
    Maybe, when you swear at the first two for not working and finally receive a non-dud. No thanks, I'll pay more and get something that works the first time.
    To wit, I don't know of many (if any) prople who've had serious problems with the HobbyCNC board.
    Mar 2003
    Shelby Twp, MI....USA
    The HobbyCNC can handle more voltage and more current, which equals more power.
    From what I've read, the tb6560 can't even be run at it's so called rated voltage.
    Nov 2011
    The reason I was asking was I have the tb6560 right now, but want to know if my speeds are low or not. I have 270 ozin Nema 23 steppers, 3/8-12 acme and dumpster AB nuts on my microcarve imposter. My max cutting speeds are 35in/min at .25 doc and my rapids are about the same speed. Thanks for your responses, I'm really curious to know.
    Registered effimos's Avatar
    Feb 2012
    Belgium
    tb6560's are good frying boards :)
    The reason I was asking was I have the tb6560 right now, ...
    well, i have 3 ..... Fried TB6560's at the moment :P
    i've bought one 3 weeks ago and it fried after 10mins, then i got a second one from the seller... fried after 5 min's.
    then i got an 'advanced' tb6560 to replace that one (3.5A instead of 3.0A)... guess what? it fried too!
    but this one did ran for one hour.
    good thing they all were sent while still in guaranty and they will be called back.
    but my conclusion (and after reading this forum) is that these boards are crap!
    My machine: [url]http://www.cnczone.com/forums/diy-cnc_router_table_machines/148958-my_new_desktop_cnc_router.html[/url]
    Nov 2011
    Quote Originally Posted by effimos View Post
    Sorry to hear about that, it hasn't happened to me yet, guess I'm lucky. You must be using the wrong settings or to high of a power supply voltage. I'm using a 24volt power supply and I had to try a few pdfs to find the right settings for mach 3.
    Feb 2012
    Belgium
    still...
    the firs time it fried it was because of the wrong settings.
    but the 2nd and third time was weird... everything worked with now using the right settings and right voltage + i connected the motors straight to the controller but when i built-in the controller to an enclosure box i had to use CB-Din connectors. with the use of these connectors between the controller and the motor the 3 chips fried imediatly.
    logicaly i thought i had connected the motors wrong but after inspecting and measuring everything this was not the case. still the chips fried and also on my 3rd board they fried.... still don't know what went wrong because i didn't meassure any short-cirquits
    Mar 2003
    Yes, that is a little slow. But part of the problem is your 12tpi screws.
    At 35ipm, your motors are spinning at 420 rpm. Most of us have found that 2-4 turn/inch screws give the best balance of speed and precision. With 4 turn/inch screws, you're speed would be close to triple, probably about 100 rpm. A better drive would probably double that still.
    With my Xylotex, and 250oz motors, I can get about 550 rpm on my Z axis.
    On my X and Y axis, I added dampers to remove resonance, and can get about 750 rpm.
    I've heard many reports of people seeing 1500 rpm with the G540.
    Feb 2012
    England
    What voltage was you running em at?
    Feb 2012
    Belgium
    Quote Originally Posted by HorridHenry View Post
    24V for 3x Nema23 motors
  • Page 1 of 2 12 LastLast
    1. Problem- tb6560-v2 red
      By tranber28 in forum Controller Cards
      Last Post: 07-03-2012, 12:31 PM
    2. Need Help!- TB6560 won't work! please help!!
      By effimos in forum DIY CNC Router Table Machines
      Last Post: 03-07-2012, 08:26 PM
    3. TB6560 are they all the same?
      By Gamble in forum DIY CNC Router Table Machines
      Last Post: 08-24-2011, 02:01 PM
    4. TB6560 Help
      By fordgt72 in forum Stepper Motors and Drives
      Last Post: 03-17-2011, 01:56 AM
    5. tb6560 help me!!!!!!!!
      By AvioP in forum Stepper Motors and Drives
      Last Post: 08-02-2010, 04:06 PM
