Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: Stepper/Servo select
    Registered sarel.wagner's Avatar
    Mar 2012
    South Africa
    Question Stepper/Servo select
    After reading numerous threads on the subject, both here and elsewhere, I am still not able to do a proper selection of motor (be it Stepper or Servo) based on fact and science.
    I build IC engines as a hobby, and because I am not a PRO I use a simulation tool to build a virtual copy and simulate the results. This works for me because I do not make stupid mistakes in component selection. When I build the engine I know the best selections were made and the combination will work and is optimised. No wasted money.
    In searching for something similar I read about Kollmorgen's Motioneering free application. Indeed what I found was heaven as it will simulate the load (X,Y Z Axiz) and give a scientifically based answer on what motor is required. Simple eh?
    My problem being I am a noob when it comes to CNC, I do have a Lathe but no Mill. Never having done CNC conversion or having worked with a Mill before I am at a loss with some of the inputs required.
    I am planning on getting a RF-45 clone and based my input to do the calculations on this, please see below:
    Here are my inputs into the Motioneering app, only Z-Axis given here, some are guesses and I do not even know if they are close:
    Z-Axis
    Load Coupling: Inertia direct entry: 1400 gm-cm2 (Stepper Rotor Inertia, I ignored the actual coupling inertia, but should not I guess)
    SCREW: Diameter 20mm, Length 350mm, Lead 5mm/rev, Nut preload 10N-m, Efficiency 90% (Not sure about the NUT pre-load value)
    FORCE: Thrust and Continuous Force (Unsure what to enter here, please explain what these parameters do and how to best use them)
    PART/TOOLING: 10KG for a part (This represents the weight of the tool and stuff clamped to Z-Axiz)
    Slide: Weight 150kg (330lbs), Elevation 90degrees(Z-Axiz), Gib force 20kg(This is a Guesstimate), Speed at Thrust Force, 0mm/sec(do not understand this parameter), Speed maximum traverse 65mm/sec (150ipm)
    Please comment and give me some direction.
    Rgrds
    Mar 2012
    South Africa
    Screenshots of the Kollmorgen app Motioneering and my inputs.
    Rgrds
    Attached Thumbnails Attached Thumbnails Stepper/Servo select-kollmorgen.jpg   Stepper/Servo select-kollmorgen_tf.jpg
    Jan 2005
    Toronto, Canada
    Just ignore the trivially small stuff, like rotor inertia. Applying the force, acceleration and power equations on the slides should give you everything you need. With steppers, you need a very large safety margin, so nothing is gained from rigorous analysis.
    Mar 2012
    South Africa
    Quote Originally Posted by H500 View Post
    Thank you for the insight. What would typical values be for the Force(Thrust and Continuous) acceleration and power?
    I am also learning all the CNC and motion related stuff as I have no prior experience, besides its educational do rigorous analysis.
    Rgrds
    Jan 2005
    Toronto, Canada
    I have a sx3 mill. I didn't bother with any calcs for the x and y, since I was certain that a 280 oz-in with a 60v driver was more than enough. If you prefer to, then use the slide friction and theoretical cutting forces.
    For the z, I calculated the watts it would take to lift the 100 lb head upwards at 100 IPM. I doubled it and then checked the motor's torque vs speed curve to determine the desired gear ratio.
    Dec 2003
    For servo's here is some motion profiles.
    Al
    Attached Thumbnails Attached Thumbnails Stepper/Servo select-inertia.pdf
    Feb 2007
    canada
    Quote Originally Posted by sarel.wagner View Post
    Z-Axis
    Rgrds
    Its a fair amount of mass with the 20mm screw and 300lb verticle lift, but the 5mm pitch helps. Definitely need a large size 34 or even a size 42. You will probably need a counter-balance so it doesn't drop when power is turned off.
    I would guess a 750-1.5kw servo for the Z axis. This is much too big for a stepper. X and Y probably could be smaller, since they are horizontal.
    Larry K
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
    Jan 2005
    Toronto, Canada
    Quote Originally Posted by Larken View Post
    That sounds like a behemoth. I doubt that my motor put out more than 60W. It can handle the 100lb head quite easily.
    Feb 2007
    canada
    A 10Hp colombo weighs about 60 Lbs, and we use a 890 oz/in size 34 stepper. (Not a ball nut but a Kerk nut.)
    You use a 270 oz.in size 23 to lift 100 lbs ?? wow (Maybe there is less gravity in toronto)
    What kind of a machine do you have that has a 100 lb head ? Is that a 5tpi screw ?
    Feb 2007
    canada
    Quote Originally Posted by cncmakers001 View Post
    Personally I suggest you choose the servo, because it is more accurate and smooth.
    What size of servo would you recommend for the specs above ?
    Mar 2012
    South Africa
    Thank you gents. Have been reading up what I could find, not a real lot. As I am not an Engineer some of the calcs is way beyond me, but I am a fast learner.
    Reading your responses in the last few posts is exactly why I want to understand motion control as best I could. Guessing and following advice blindly, that's just not me.
    I managed to come to the conclusion that a RF-45 and Clone cannot be run properly by stepper, or cannot be run well if ya like. Each axiz demands between 230 and 400 watts to drive em, squarely in Servo territory.
    Attached the Z-axiz PDF from Motioneering as well as the complete export. If one of ya will be so kind as to check my inputs and answers, will really appreciate that! (Delete the .txt extension from ZX45-sarel.exp.txt) and import in Motioneering.
    I do not have my Mill yet and had to change my plans from the ZAY7045 to the ZX-45 as the ZAY is only available with MT3 spindle and that sucks, no tooling available but the cheap China imports. We use a lot of R8 in SA so Industrial supply abound with anything R8
    Some of my input values are guesses or values obtained here in various build threads. Please advise if anything is off realistic values.
    Thanking ya all in advance.
    Rgrds
    Attached Files Attached Files
    Jan 2005
    Toronto, Canada
    Exclamation
    You use a 280 oz.in size 23 to lift 100 lbs ?? wow (Maybe there is less gravity in toronto)
    If you don't use ball screws, then your motor needs to be 2 to 3 times bigger than mine. But 890 oz in still seems like an overkill for a tiny 60 lb head.
    I have an SX3 mill with 5tpi ball screws. Just for fun, lets do some rough calculations.
    Head weight+slide friction = 120 lb = 55 kg = 540Newtons
    Gear ratio = 1.6
    Ball screw ratio = 5
    Motor torque drops to about 70% of static value as soon as motor moves:
    Motor torque = 280 x .7 = 196 oz in / 16 = 12.25 lb in
    Convert motor torque to ball nut force, assuming 80% mechanical efficiency.
    12.25 x 3.14 x 1.6 x 5 x .8 = 245 lb
    This is about double the weight of the head. It's a reasonable amount of over design.
    Ignoring accel and assuming I want about 120 IPM, the required minimum motor power is:
    Speed = 120 /60 = 2 ips x .0254 = .0508 meter per sec
    Power = 540N x .0508 = 27W
    If I didn't make a mistake somewhere, the calculations show that my motor is easily up to the task.
    The sx3 uses thrust bearings which rubs on the sides when turning. Acceleration is also not negligible. I am also using only 34v for now, so the motor torque drops as the speed increases. In practice, I am getting 60 to 80 ipm reliably. I fully expect to get 120ipm or more once I replace the bearings and use a 50v power supply.
  • Page 1 of 2 12 LastLast
    1. Replies: 0
      Last Post: 11-14-2011, 03:40 PM
    2. Need Help!- derate stepper and select power supply
      By bullethead67 in forum Bridgeport and Hardinge Mills
      Last Post: 02-27-2010, 03:04 PM
    3. STEPPER v/s SERVO
      By sanjiv in forum Stepper Motors and Drives
      Last Post: 11-15-2007, 05:29 AM
    4. Servo or Stepper
      By Cartierusm in forum General Metal Working Machines
      Last Post: 09-16-2007, 04:26 AM
    5. servo vrs. stepper
      By ints99 in forum General Electronics Discussion
      Last Post: 09-01-2005, 05:19 PM
