Page 2 of 2 FirstFirst 12
Results 13 to 16 of 16
Thread: HELP! Nema 23 steppers!
  1. #13
    Mar 2003
    Shelby Twp, MI....USA
    The .xml contains your Mach3 settings, so I can try to see what's causing the problem.
  2. #14
    Jan 2005
    Toronto, Canada
    Command it to move .1" and see how far it moves.
  3. #15
    Mar 2012
    canada
    I run out of space on my 30" axis. But that's only when I load cam bam g code
    I am here: http://tapatalk.com/map.php?uwcjgi
  4. #16
    Mar 2012
    canada
    Hi!
    I figured out the problem!
    It was the crappy Mach 3 the came with my Chinese driver board. I bought a mach3 license and it's works perfectly!
    Thanks for the help
    I am here: http://tapatalk.com/map.php?wr05cc
  1. Need Help!- NEMA 42 vs 34 12nm Steppers
    By brumby in forum Stepper Motors and Drives
    Last Post: 10-19-2011, 08:24 AM
  2. Need Help!- Looking for nema 23 steppers CHEAP!!!
    By maxlkauker in forum Want To Buy...Need help!
    Last Post: 03-04-2011, 01:54 AM
  3. Wanted: Broken Nema 23 and 34 steppers
    By groomden in forum Want To Buy...Need help!
    Last Post: 12-23-2008, 12:52 PM
  4. 570 oz/in nema 23 steppers
    By cut more in forum Stepper Motors and Drives
    Last Post: 10-01-2007, 07:03 AM
  5. 3 (triple) stack, NEMA 23 steppers
    By Wm McNett in forum Stepper Motors and Drives
    Last Post: 11-05-2005, 09:52 PM
