Results 1 to 2 of 2
Thread: Drivers Enable
    Feb 2012
    England
    Drivers Enable
    What are them 'Enable' +&- really for? since in most cases they're not needed connected.
    Registered neilw20's Avatar
    Jun 2007
    Depends on the driver make and model. Some might not even have an enable/disable input.
    Some need it enabled with current thru the opto.
    Others disable when current through the opto.
    The + goes to +5v through a resistor, typically 330 - 680 ohms.
    You can use 12v and a 1K resistor or 2K2 1/2w with a 24v supply.
    The - side is switched to 0v by a BOB output or a switch, or a part of the machine safety circuit.
    When disabled the stepper is free to turn. (no motor current)
    It can be used to freewheel an axis.
    Never disconnect stepper wires to freewheel an axis. That will probably destroy the driver.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
  1. Need Help!- Enable Macro
    By tc26 in forum Haas Mills
    Last Post: 04-23-2012, 11:43 AM
  2. Randtronics Enable
    By efinkg in forum HURCO
    Last Post: 08-20-2011, 05:12 PM
  3. Enable voltages on M1 pin 1
    By dodgy74 in forum CncBrain
    Last Post: 01-04-2010, 04:35 PM
  4. Need Help!- Enable how????
    By mjhooo8 in forum LinuxCNC (formerly EMC2)
    Last Post: 09-13-2008, 02:27 AM
  5. Enable connections on drivers
    By metalhacker in forum Stepper Motors and Drives
    Last Post: 06-12-2005, 02:43 AM
