Page 1 of 2 12 LastLast
Results 1 to 12 of 20
Thread: Pairing an 8 wire Steeper Motor
    Registered EKFER's Avatar
    Apr 2011
    Hello Esteemed Colleagues: I need your help in converting my 8 wire motor to 4. I do have the datasheet, but I don't understand the wiring diagram. Thus, I don't know which wires I have to connect together. The motor is a 23j1854-828 (see the attached picture).
    Note: There is little information (that I could find) in dealing with the interpretation of the symbols. Thank you
    Attached Thumbnails Attached Thumbnails Pairing an 8 wire Steeper Motor-23j1854-828.jpg
    Registered KOC62's Avatar
    Mar 2009
    Well, the coloured wires are shown on the diagram. You will need to decide which type you want, namely high torque or high speed connection?
    What contoller are you using? You need to know the current rating for your controller board and your motor for each each possible wiring condition, like uniploar, bipolar, bipolar series, etc.
    Let us know, then we can walk you through a possible connection.
    May 2004
    Wink YEP
    Quote Originally Posted by KOC62 View Post
    What he said.
    Apr 2011
    I have the information you requested
    Thank you for your rapid response.
    The connection is for high torque.
    The driver is a 2m542 4.2amps.
    The breakout board is a HY-JK02-M 5 axis.
    The motor is rated at 2.8 amps.
    The PSU is 24volts 15amps.
    I will have 3 axis only.
    The datasheet shows the wire colors and the winding diagram. But I don't know what the symbol represents. I wish that, additionally, it would list the color pair cables that go to: A, A-, B, B- with words.
    Then, I could be handling the connections from tthe motors to the drivers. Thank you
    Mar 2009
    This first diagram at the bottom gives the coloured wires and how they are connected in high torque. The next diagram represent the equivalent 4-wire result showing the A/A- and B/B- coils.
    According to the diagram for "High torque";
    This is a SERIES connection.
    Join YELLOW wire to RED wire
    This gives you the two wires for the A coil which you connect to your driver;
    +A BLUE
    -A GREEN
    The B coil;
    Join BLACK wire to ORANGE wire.
    This gives you the two wires for the B coil which you connect to your driver.
    +B BROWN
    -B WHITE
    If you decide to use the "High Speed" wiring then do the following.
    This is a PARALLEL connection
    Join GREEN to RED
    Join YELLOW to BLUE
    This results in;
    +A BLUE/YELLOW pair
    -A GREEN/RED pair
    Join ORANGE and BROWN
    Join BLACK AND WHITE
    This results in;
    +B BROWN/ORANGE pair
    -B WHITE/BLACK pair
    Feb 2012
    England
    Just a note about the switching arrangement.
    I have bought three rotary switches so that if ever I need speed from my steppers rather than torque then all I have to do is switch from Torque to Speed on the rotary switches.
    Registered James Newton's Avatar
    May 2005
    There is a list of all the connection options at: techref.massmind.org/techref/io/stepper/connections.htm along with the advantages and disadvantages of each.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Mar 2009
    James-Newton,
    That is a good reference you provided.
    I gave the wiring in a my earlier post because I thought he didn't know how to wire his specific motor using his motor's wiring colour code. Your reference may not provide that info. I too recommend that he read the provided link for further insight.
    Apr 2011
    Thank you note
    I'm deeply thankful for the information. I will visit the sites listed. Now I can read the datasheets of other motors since you show me how the diagram connections work. I updated my previous picture with the combinations you showed me. Thank you again
    Attached Thumbnails Attached Thumbnails Pairing an 8 wire Steeper Motor-miscellaneous_ekf_cnc_project_slides-3.jpg
    Mar 2009
    Excellent. Those "Eureka" moments.
    Things are always simpler once one understands.
    Sometimes us experienced folk don't realize what is not clear to the uninitiated and we make the wrong assumptions.
    Tinkerer
    Nov 2009
    I believe your second drawing "wiring for high speed in series" is wrong. Not in the schematic but in its term. I believe this type of connection is referred to as parallel. In fact your diagram almost proves it as all wires are drawn parallel. Would someone please confirm or deny my suspicion?
    Quote Originally Posted by EKFER View Post
    Mar 2009
    fastest1
    The labelling is confusing since both say "8 lead Wire series connection".
    You are correct in that the parallel bipolar connection gives the highest torque while the unipolar connection gives the highest speed.
    Also see james newton's link in post #7 for further info.
    I assumed that ekfer read that link's info fo clarification.
  • Page 1 of 2 12 LastLast
    1. Need Help!- steeper motor
      By rhincan in forum Plasma, EDM and other similar machine Project Log
      Last Post: 11-14-2011, 03:04 PM
    2. Running stepper motor wire with router wire?
      By basskitcase in forum DIY CNC Router Table Machines
      Last Post: 02-19-2010, 11:18 AM
    3. Need Help!- Steeper motor humming
      By frankg521 in forum Stepper Motors and Drives
      Last Post: 05-14-2009, 06:05 PM
    4. Need help pairing Gecko's with motors
      By isvflorin in forum Gecko Drives
      Last Post: 12-07-2008, 09:03 PM
    5. How To select Steeper Motor
      By mohamedtaha in forum Stepper Motors and Drives
      Last Post: 06-21-2006, 07:02 AM
