Using Geckodrive's recommendations, your motor current would be 2/3 *3amp = 2 amps.
Keep in mind these are guidelines, not requirements. The actual power will depend on your system. If it's lightly loaded, you might be able to get away with far less. I've been using a single 2 amp supply to drive two 3 amp motors for the past month with no issues on my development system.
LinkBack URL
About LinkBacks
or do i need that kind of linear force at 180ipm rapids
