Results 1 to 1 of 1
Thread: my L297 L6203 doesnt work ?? :(
    Oct 2011
    algeria
    Hey everybody,im new member here in this great site,i became so interrested in the cnc field and after Effort of self- i understand how it works with these beautifull machines,idecieded to build my own router cnc 3axes using L297 L6203 chips (4A) for the motor driver ,and with easy interface (itook it from * Geoff Williams, "CNC Robotics: Build Your Own Workshop Bot"
    my power is three pc power supply parallel connection In order to ensure 34V 7A
    my motor bipolair NEMA23 4wires current per phase (3A 4,2V),impédance 1,4ohm
    After i put my DB interface and the driver card under power (5V) i switch on for the 34V , iturned the variable résistance (2,2k) but nothing move i tested the step pin it was fixed on 3,87 V and the direction pin it was variable but around 2,2 V,i tested also the A- A+ ,B- B+ but its 0 volts.
    Im not Professional in electronics i'm just Amateur and i need help because i spent money and time to realize my machine ,for more information in test points in my driver card im ready to do.
    I feel upset after my Failure but i'm sure the professionals here will helps me
    i attached the interface card and the driver card Schemes.
    thx
    Attached Thumbnails Attached Thumbnails my L297 L6203 doesnt work ?? :(-interface_card.jpg   my L297 L6203 doesnt work ?? :(-bcp_driver_card.bmp
  1. CONTROLADORA BIPOLAR CON EL L6203 -l297
    By lupi200 in forum Spanish CNCzone
    Last Post: 11-20-2011, 09:39 PM
  2. l297 l6203 problemas
    By hoal in forum Spanish CNCzone
    Last Post: 04-01-2010, 05:15 PM
  3. L297 l6203
    By Konstantin in forum Open Source Controller Boards
    Last Post: 05-09-2009, 12:54 PM
  4. need help on L297+L6203 driver
    By xinzc28 in forum Stepper Motors and Drives
    Last Post: 03-25-2009, 07:06 AM
  5. Questions/Reviews About L297/L6203 Drivers...
    By Brenck in forum Open Source Controller Boards
    Last Post: 02-25-2009, 08:36 PM
