Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: TURNING ON AND OFF MY ROUTER
    Oct 2007
    I have a PMDX122 BOB, Gecko G203V drivers and a SSR relay that needs between 3 to 5 volts to be activated and can handle 120AC Volts and 30 Amps and running Mach3
    Here is what I want to do, I would like that Mach3 would start and stop my router with the proper Gcodes.
    Can you tell me if it is possible and if so guide me to these steps.
    Thank you
    Mar 2003
    Shelby Twp, MI....USA
    Connect the relay to an output pin.
    In Mach3, go to Ports and Pins > Output Signals, and assign that pin to Output #1.
    Then go to the Spindle Setup (still in Ports and Pins), Uncheck "Disable Spindle Relays" and assign Output 1 to "Clockwise (M3)". You may want to add a few seconds of delay to "CW Delay Spin Up" So the router is up to speed before it starts cutting.
    Now M3 should start your spindle, and M5 should stop it.
    May 2007
    guatemala
    • gracias por la explicación
    Oct 2007
    Thank you for the information, sorry I didn't came back to you earlier, I was out of town.
    Has soon that I will have time I will give a try.
    Oct 2007
    SSR relay
    Hi to all
    I have install a SSR to turn my router on and off, it is working properly when Mach3 is open, my BOB is a PMDX122, so can I ask for more ? Maybe
    My problem is when I start up Windows the router also starts, when I can think about it I shut down the router manually before closing Windows, but this situation is on the dangerous side.
    Any help will be appreciated
    Thank you
    Dec 2003
    Especially if using an SSR you should also have a an E-stop relay that shuts power off the drives and spindle.
    Once the PC is booted up and ready, releasing the E-stop enables both drives and spindle.
    Oct 2007
    I have limits switches and an Emergency Stop install, is the EStop relay the same thing that the Emergency Stop that I already have.
    Thank you for the reply
    Dec 2003
    If you have an Emergency stop (E-stop) it should remove input power to the drives and spindle by relay IOW the coil(s) should be hard hardwired in the E-stop circuit.
    Registered bozidar22's Avatar
    Feb 2010
    does the pmdx 122 have a charge pump. my pmdx 125 has one to keep things off untill it gets a signal from mach 3
    Mar 2003
    Quote Originally Posted by BOBINETTE View Post
    Hi to all
    Thank you
    You're machine should never have power applied unless Mach3 is up and running.
    Your board does have a charge pump to prevent this, but the safest way is to not turn on the power until Mach3 is running, and turn the power off before shutting down Mach3.
    Oct 2007
    Yes it have a charge pump (Watchdog)
    Oct 2007
    How can I activate the charge pump
  • Page 1 of 2 12 LastLast
    1. Turning using a G50 or a G92
      By camtd in forum G-Code Programing
      Last Post: 05-16-2013, 07:21 AM
    2. Need Help!- Pinch turning or Balanced turning
      By pradeep in forum Mori Seiki lathes
      Last Post: 09-07-2010, 02:55 PM
    3. Turning 17-4
      By shep640 in forum Mini Lathe
      Last Post: 04-07-2009, 05:50 PM
    4. Turning on a cnc router.
      By skipper_52 in forum DIY CNC Router Table Machines
      Last Post: 04-14-2008, 03:39 PM
    5. Turning S7 vs. D2
      By wildcat in forum General Metalwork Discussion
      Last Post: 07-06-2007, 10:06 AM
