Page 3 of 4 FirstFirst 1234 LastLast
Results 25 to 36 of 38
Thread: Found a long lost kit, now what?
  1. #25
    Registered judleroy's Avatar
    Dec 2006
    Sounds like you might be better off (and safer) spending 50-100$ at keling and get a power supply you don't need to wire yourself. Lol.
    Judleroy
  2. #26
    Apr 2004
    Florida
    Heh. Yeah. Well, I got it. 24VDC with no smoke, no popped breakers, no scary noises, and I had the TV, computer, and ceiling fan all on. Hey, I learn by doing (and sometimes failing), and I learned a lot so far. Now to hook up the capacitor and shock myself to death. I've got a 1.5k 5 watt resister between the terminals per the instructions. After that, it's all easy. lol /knock on wood
  3. #27
    Registered Bubba's Avatar
    Mar 2004
    LaGrange, GA USA
    Congrats on making progress! :})
    Learning by doing is the best way. Shame I or somebody else can't be there looking over your shoulder only to stop you if your doing something bad!
    Hang in there. This is the way we all learn.
    Art
  4. #28
    Apr 2004
    Florida
    Thank you sir. I'm now trying to find some 6 pin connectors so I can wire the connections to the motors. I figured this whole project would only take me a few days. Wrong...
  • #29
    Mar 2004
    LaGrange, GA USA
    Why 6 pin connectors? If your thinking of putting the power lines of the geckos and the encoder lines in the same plug, I highly recommend against that! You want to keep the encoder lines and the power lines separate because of possible cross talk (noise) .
    Art
  • #30
    Apr 2004
    Florida
    Hmm. The instuctions say to use the 6 pin connector- even gives the Mouser part number. They are expensive from Mouser, so I thought I'd try looking around. Maybe not now. lol The cable I was going to get is shielded, but maybe I'll get 4 conductor shielded wire for the encoder and then just zip tie a regular 2 conductor lamp cord to it for the motors. How about that plan?
  • #31
    Mar 2004
    LaGrange, GA USA
    I keep my power wires WELL separated from the encoder wires.
    And in the control box, encoder wires and power wires are not run parallel to each other. And when they have to cross, it is done as close as possible to 90°
    Art
  • #32
    Apr 2004
    Florida
    My controller box is almost finished. I was about to install some connectors when I noticed that several commercially available servo controllers use Cat 5 cable (with presumably only a few of the wires). Since Cat 5 is 24 gauge, and my instructions say to use 22 gauge, I'm wondering if this is a good idea. It would certainly be easier- I have a cat 5 wiring tool in my toolbox. Any thoughts?
  • #33
    Registered bobsch's Avatar
    Oct 2008
    Quote Originally Posted by c131fr View Post
    Most Cat5 uses solid conductors, not a good idea for cables that will be flexed.
    Bob
    "Bad decisions make good stories."
  • #34
    Sep 2011
    Quote Originally Posted by bobsch View Post
    I would go with heavier gauge as well
  • #35
    Apr 2004
    Florida
    Ok. I have shielded 4 condutor wire that's stranded and 22 gauge, but I just thought it wuold be easier to use the cat 5 connector. I wonder if I could stuff the 22 gauge wire into the connector. lol
  • #36
    Mar 2004
    LaGrange, GA USA
    I used db9 connectors for my encoder lines!
    Art
  • Page 3 of 4 FirstFirst 1234 LastLast
    1. PUMA350B LOST PARAMETERS/ FOUND
      By ITT-Student in forum Daewoo/Doosan
      Last Post: 11-13-2011, 03:49 PM
    2. Need Help!- no sim found
      By wronggrade in forum Mastercam
      Last Post: 11-17-2010, 06:27 PM
    3. I found that..
      By tigerhellmaker in forum Controller & Computer Solutions
      Last Post: 11-04-2008, 07:44 AM
    4. I found...
      By amurphysmu in forum DIY CNC Router Table Machines
      Last Post: 09-13-2005, 02:50 PM
